Horn Wiring
  • panz4ever
    • Mar 2009
    • 197
    Horn Wiring
    Anyone have a pic or can explain how wires are routed from the front terminal panel to the horn. This is for my 49 EL. I would think that the 49 and early 50 pans are basically wired the same or very similar.
    Searched this forum and a couple of others for answer but so far no luck.
    • 5950
    The 1949 Terminal Board (terminal plate)is located inside the fork tins. Behind the headlamp.
    • panz4ever
      • Mar 2009
      • 197
      Thanks Chrisbut I guess I need to explain a bit better. HD ran wires along a certain path of the bike (from point 'A' to point 'B'). Easiest example being the spark advance wire and the throttle cable wire. They also ran a certain path (or so it seems from looking at a lot of pics) for the wiring harness from the terminal boards in the fork plate to the ignition switch as well the one on the seat post frame over to the brake switch and such.
      So what i am needing is to knowhow the horn wires go from the terminal board to the horn posts...come out on the right or left side of the neck and how they snake they way down and out.
        • 5950
        The wires come out of the tins with the loom on top of the frame and drop down between the tanks and to the horn.
        • panz4ever
          • Mar 2009
          • 197
          Thanks Chris. Makes sense now that I look at it.
            • 5950
            Notice the cut out on the back of your dash cover and you will see where to put the wires.
            • Matthew N. Olse
              • May 2007
              • 102
              Panz4ever,
              Check out my blog at www.oldbikesinsd.blogspot.com for some great 49 pics that show you what you need to know about routing the wires on your 49. I just took the pics of my daddy's original paint 49 today. I hope they help you and others out!
              best,
              Matt Olsen
              A.M.C.A. Board Member
              www.pre1916scramble.blogspot.com
              • panz4ever
                • Mar 2009
                • 197
                Wow Matt, cannot thank you enough I know it REALLY helps me.
                • DaveSwanson
                  • Oct 2007
                  • 66
                  Great photos Matt. Thanks much.
                  Dave Swanson
                  1956 FLH
                  1969 FLH
                  1964 XLCH
                  1956 KHK
                  1936 VD
                  AMCA 11659
                  • Glenn
                    Member to Remember
                    • May 2007
                    • 403
                    thanks trying do a 1950 pan over soon it will definately help
                    Moose
                    aka Glenn
                    • Matthew N. Olse
                      • May 2007
                      • 102
                      Glad to help you out with your project. I try to update the site once a day as long as I am in South Dakota. Let me know if you need any more pics and I will set you up.
