Location of starter relay
    • 5953
    Who can tell me where the starter relay is located on my 1995 FLHTCU? The wiring diagram is no help.
    TIA,
    Chris
  • bmh
    • Feb 2007
    • 901
    Chris,It is under the fairing. Remove the headlight assembly and the relays are beside the fuse block. If you have the factory service manual fig. 8-109 on pg. 8-152 shows a diagram of what lurks under there. You should be able to get at it without removing the fairing, the same can't be said if the light bulb in your oil or volt gauge goes out though. Can E-mail a copy to you if you need.
    Brian Howard AMCA#5866
      • 5953
      BMH,
      I have that illustration. It doesn't list the Starter Relay there.
      • Rooster
        • Mar 2009
        • 543
        Chris, see item #21 in the list on that illustration.
          • 5953
          Ah so. I didn't notice that. Thanks Kid!
          • Rooster
            • Mar 2009
            • 543
            Whattam I gunna do with this old geezer...???!
            • Paps
              • Jun 2003
              • 1814
              Buy him a code reader ! LOL
