After-Market Springer Horns
  • Ohio-Rider
    Supporting Member
    • 852
    I’ve just had the third springer horn in seven years go bad on me. Has anyone found a way to repair them or at least found a way to make them last longer? These things ain’t cheap and I’m running out of money.
    Steve
    AMCA #7300
  • rwm
    • Dec 2006
    • 1302
    someone told me if you don't use the horn it will last forever .got my 12v from way back wheels.but i don't use it much
    rob ronky #10507
    www.diamondhorsevalley.com
      • 5952
      Step up and buy a Delco 16 OEM horn. They last forever.
      • brillson
        • Jun 2004
        • 31
        Yes Chris, the wisest investion.
        Martin Brill
        www.brillantparts.com
        • Ohio-Rider
          Supporting Member
          • 852
          Thanks for the info. Now let me go see if I can find one. I did a quick search at the Delco site but had no luck. At least I know what to look for now. Thanks again.
          Steve
          AMCA #7300
            • 4785
            Steve,
            Be aware that the Delco 16 was used in various applications, both automotive as well as motorcycle so different types have different mounting arrangements. Original H-D horns are on eBay all the time but can get pricey. Be patient and look often and you might be able to pick one up at a good price.
            Robbie
            • Paps
              • Jun 2003
              • 1814
              I don't just attend the local RUB swapmeets to see old friends Steve. I go to look in their....what they believe is junk.......boxes under their tables. Paps
              • Ohio-Rider
                Supporting Member
                • 852
                Thanks Robbie,
                I'll keep my eyes open for a cheap one. I really need two though cause the one on the 45" doesn't work either. Maybe when my stimulas check gets here I'll be setting fat.
                Paps,
                Oh man! Did you see something under a table I didn't see. Hell and all I got was that dinged up old air cleaner. LOL
                Steve
                AMCA #7300
                • D.Mac
                  • Feb 2007
                  • 239
                  Horn repair
                  Steve,
                  Sometime back Perry Ruiter posted a link on this forum to his excellent article on horn repair. Maybe you can fix yours. http:/www.ruiter.ca horn overhaul
                  Doug.
                  (It doesn't look like this link is going to work, but I typed in the search and it does come up, it can also be searched on this forum under horn repair.)
                  Doug McLaughlin #6607
                  NorCal, USA
                  • rbenash
                    • Jul 2001
                    • 643
                    Hmmm, ahem - anyone have the Delco part number for the horn that came with the 65 pan or later shovels? Can't seem to find one. One I have is the much later HD replacement, and would like to find the original correct Delco part#. I just might have one but want to make sure it's the right one.
                    Ray
                    AMCA #7140
                    • Perry Ruiter
                      Henderson KJ wanted!
                      • 621
                      Originally posted by D.Mac View Post
                      Steve,
                      Doug.
                      Here's the direct link to the article. One day I hope to update it with photos ... Perry
                      • Ohio-Rider
                        Supporting Member
                        • 852
                        Thanks Perry, That procedure of yours gives me something to try as well as a good description of how these horns work. I’ll check it out and let everyone know what I find.
                        Steve
                        AMCA #7300
                        • Ohio-Rider
                          Supporting Member
                          • 852
                          Great procedure Perry. I got two of my horns working again last night using your instructions. Now I even have a spare. You saved me a nice chunk of change. Thanks again. -Steve
                          Steve
                          AMCA #7300
