Best magneto for Sportster "CH"?
  • Coolbreeze
    Long Rider
    • Aug 2007
    • 320
    I may have to replace my stock Fairbanks-Morris magneto on my '60 CH because of clearance problems. Both Hunt and Morris make a shorter magneto that should work. The Hunt is about $100 cheaper than the Morris. They both use rare earth magnets and claim to be well sealed. BTW, I will not throw away the old mag.
    Does anyone have an opinion as to whether the Hunt or the Morris magneto will perform better? I do not intend to run the bike at the drags, but I want it to start and to keep running. I take fairly long trips; so, reliability is important.
    So, what should I get: Morris or Hunt?
    George Tinkham
    Springfield, IL
    www.virmc.com
    AMCA # 1494
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    1984 Moto Guzzi V65Sp
  • mmoore
    • 193
    I have used both and never had a problem with either. so I would go by price this time. just tune as required and use the correct plugs and wires. I have had bad performance from those skinny tipped plugs. seems that they dont last long so I went back to my ac delcos as I get 3-4 times the life out of them. it starts better with a fat spark. anybody else had plug issues with modern plugs?
    3899
    • 40 Nuck
      • Mar 2008
      • 221
      Don't the Morris Mags have the advance ring and the Hunt's do not? I know that's what I found on the Knuckle mags, but this may not be the case with the Sportsters. If so, I would recommend the advance ring for easier starts.
      Vic Ephrem
      AMCA #2590
        • 5953
        Just out of curiosity, what is the clearance pfoblem?
        • joestuff
          • Mar 2007
          • 49
          Couple of things, as I talked to the Morris people today. They can rebuild your stock for less then a new one. A buddy of mine had his done and is very happy. Both of mine are going in this winter.
          Yes, they do make an "impulse" thing that uses a spring to spin the magneto at kick speeds, so you don't have to worry about moving the kicker fast enough to make a spark.
          No, it will not fit on Sporsters with most carb options, cause it raises the magneto up a bit. I have had a CV, bendix, SS G and Linkert side bowl on my two sportsters, The bendix is the only one with enough clearance to between the carb and the cap to fit anything. Of course you could make it work somehow...
            • 5953
            Hey Coolbreeze.
            Are ya gonna tell us what the clearance problem is?
              Just for the hell of it! Fairbank makes the mag. All Morris and hunt do is put there name on it. Morris is only tweanty miles from me and Iv'e had them rebuilt two mags. Great people. Great workmanship. A+. Bob
              • Coolbreeze
                Long Rider
                • Aug 2007
                • 320
                Hey Coolbreeze.
                Sorry it took ~10 years to get back to you, but I have been distracted. The clearance issue is that the CH was bought with a S&S carb that does not leave much room for the mag if an advance plate is inserted between it and the case. I want to manipulate the spark advance with the left handlebar grip, like I do on my '56 H-D KHK and my '48 Chief.
                George Tinkham
                Springfield, IL
                www.virmc.com
                AMCA # 1494
                1941 Indian 841
                1948 Indian Chief
                1956 H-D KHK
                1960 CH
                1964 BMW R69S
                • FNG1
                  • Oct 2014
                  • 201
                  Hey Coolbreeze, my 67 XLCH had a Hunt magneto with an aftermarket adjustable base and a bored out DC Linkert with no clearance issues. I can't remember the maker but it had a slotted brass and steel plate and a spring to hold it advanced. P3250048 (3).jpg
