Splitdorf NS2 timing
    • 1669
    My magneto fires late, if I advance the spark fully the rear cylinder stops firing (maybe starting halfway through the advancing stroke). I know it should spark at 7/32 (.2187) BTDC when fully advanced, but the points don't open until .185 BTDC on the front and at .169 on the rear.
    Before I go to the hassle of opening up the motor timing case to check there, I'd like to verify that the fiber gear for the rotor and the steel gear for the breaker cam meet at the correct spot. I've located both timing marks for those gears, put a spot of white paint on them, but the point where they mesh is hidden.
    How can I get a clear view of that meshing spot? Pull the rotor assembly? Or pull the breaker plate? Or both? Or neither?
    And how do the rotor assembly or the breaker plate come off? I don't want to mess things up more than they already are and I can't find an answer! Thanks!
    • 1669
    ...this is what I'm looking at, an NS2 with the points cover and distributor cap removed. The top u-shaped thingy up high with the pointer at the end holds the rotor (removed), and the bottom is the points breaker with the breaker cam in the middle:
    ...and this is one way to test for when the points open, there's a 6V lantern battery in the circuit with a small light and two clips attached to the both points, I've got the front cylinder head removed so I can measure the BTDC:
    • gharper
      • Nov 2009
      • 527
      In order to accurately check the proper meshing of the timing marks, simply remove the points assembly. Use a 5/16" deep socket and remove the two long studs on either side of the points assembly. Lift the plate out and check. Be sure to lube the plate where it rotates on the body and copper springs before reassembly. I'd go with a minimum of 3/8" BTDC, but 7/16" is fine too. You may need to advance the timing by a tooth. Also, playing with point gap will make a big difference on timing. I believe the Splitdorf book says .020" point gap but I've adjusted mine up to .024" to get my full 7/16" advance on my Excelsior and Chief.
      In addition, check timing on BOTH cylinders, it will be different! There is a bit of fudge on the pin that locates the cam as well as the cam gear on the shaft. Both of those can be used to gain a bit of advance. Be sure when checking timing that all of the slack is out of the gear train. I use a big screwdriver in the slot for the cam retaining screw, gently holding reverse pressure on the train.
      Also, the timing of the U shaped retaining clip that holds the rotor must point to the correct wire for each cylinder. When the points are opening on the short lobe, the rotor must point to the rear connection on the cap, with the wire going to the front cylinder. The large rear cam, is for the rear cylinder and when opening the points, the rotor must point to the front wire connection, which goes to the rear cylinder. Check that the rotor is contacting the brass wiper in the cap with the spark fully advanced, as well as fully retarded, for both cylinders. If the timing marks are off, or have been altered, it may be that the rotor brush is not making contact at full advance, or retard.
      Keep in mind that in order for a magneto to produce the hottest spark, two things must happen simultaneously: The rotating pole must break the magnetic field at the exact same time that the points open. Easy on a fixed timing mag, but your mag has adjustable timing, so rotating the points will change this ratio. The hottest spark is in the middle of the points rotation. That means that full advance and full retard are actually weaker sparks. This usually isn't an issue if the magnet is fully charged, but can sometimes cause hard starting and a miss at very low speeds. One thing that can help here is to decrease the spark plug gap, so a weaker spark can actually make the jump at very low speeds, or starting. I set my plug gap at .015" and have had good luck all around. This may help with the missing on the rear cylinder.
      Good Luck!
        • 964
        I don't think a test light or multimeter will accurately show point break on magneto..
        I use an induction magneto timer or a timing light with flywheel marks made during assembly ,visible thru vent line hole while running.
        • gharper
          • Nov 2009
          • 527
          Tom, on the Splitdorf, it will show quite accurately when the points open. However, the wire leading to the coil must be removed from the circuit. This in effect will use the breaker points as a switch to ground, with the coil and condenser out of the circuit. I can see that pisten-billy has done just that. On a shuttle wound magneto with a rotating coil, it isn't possible to get the coil and condenser out of the circuit so using a light on the points is not accurate.
          Timing marks are a very good idea. On the total loss motors, I use the hole on the left crankcase where the hand oil pump dumps oil into the crankcase. Remove the oil line and elbow and you have a straight shot to the edge of the flywheel. I put marks for TDC and timing marks for both cylinders there. I use a different symbol and color of paint for each. Then the important thing is to record this info! I have it on a note card inside the magneto, plus in my book for each motor.
            • 964
            Thanks,my mag is a shuttle wound and did not realize the difference with ns2
              • 1669
              Gene, thank-you for the very detailed reply! It's really, really appreciated considering the dearth of information I've been able to find. Of big value is this forum and the knowledge to be gained from experienced people willing go take the time to share and put it in writing for others to source...so thanks again!
              I did find the fiber gear and steel breaker gear to mesh properly on their marks, so on to the next step...maybe re-gap the points and see how much that helps. But I'm a long way from 3/8" BTDC, and I've seen other places state that 7/32" BTDC is for a 37c.i. motor (my motor)...but I'm not certain if that's legit!
                • 1669
                Thanks Tom, but we didn't put any marks on the flywheel!
                • PaulCDF
                  • Aug 2019
                  • 1415
                  Not sure if my contribution will add more smoke or light to the problem here are a couple of pages from Dykes Automobile and Gasoline Engine Encyclopedia:
                    • 1669
                    Thanks Paul, I'd already seen that and it doesn't really apply...but thanks for looking!
                      • 1669
                      ...still futzing around with timing this magneto! In the timing case I moved one tooth on the magneto gear to fire fully advanced at .420...still the rear cylinder won't fire unless timing is retarded. BUT I noticed something that makes me wonder if this is my problem, the spool driver that holds the rotor is quite sloppy, there's at least +.06 movement in the rotation due to gaps where the tabs on the spool mount to the rotor shaft:
                      here is a short video showing the rotational movement:
                      and a small bit of movement laterally:
                      Does the rotor spool need to be tight on the shaft with little or no movement? I'm guessing it does, but then maybe the fact that the rotor only turns one direction means it is forced to one side of the gaps?
                      Here's the track inside the cap for the rear plug...something 'ain't right there:
                      • PaulCDF
                        • Aug 2019
                        • 1415
                        Harry Forgive me if you have seen:
                        Spring Issue 1997 Vol 36 #1
                        Tech Tips (starts on page 40)
                        THE SPLITDORF GENERATOR
                        Identification Care and Feeding by Steve Blanchard
                        Fall 2011 Vol50 #3
                        Restoring Repairing and Riding by Fred Johnson (starts pg 64)
                        Tracking Down the Source of Magneto Failures
                        Winter 2011 Vol50 #4
                        Restoring Repairing and Riding by Fred Johnson (starts pg 65)
                        Solving the Problem of Magneto Condenser Failures
                        All The Best
                          • 1669
                          Thanks Paul! You are indeed the "wizard" of research and I'll look those up!
                          now...if there were only a link somewhere on the Forum pages back to the AMCA site...hmmm
                          • PaulCDF
                            • Aug 2019
                            • 1415
                            Harry
                            Was thinking about your challenge with this Magneto:
                            I don't know if you do fb they have a 101 group there and a Splitdorf group. If you don't have a magneto guy this gent seems highly recommended (though I have never personally dealt with him) talks about rebuilding a Splitdorf for an Indian 4 for the Cannonball:
                            "We repair and rebuild magnetos for vintage tractors, motorcycles, Stationary engines & more. Call or e-mail if you have any questions. 651-233-6655 rebuiltmags.com - Rudy, Kenny, Mike, Pat and Dan
                            21440 Forest Blvd. N, Forest Lake, MN, United States, 55025
                            rudy@rebuiltmags.com"
                            I enjoyed your youtube posts perhaps a more trained eye would see something amiss.
