USB Charger for 6 Volt System? Looking for Solution
  • USB Charger for 6 Volt System? Looking for Solution
    I don't recall seeing this issue addressed. Has anyone found a solution for USB charger that works on a 6 volt system to power a phone, GPS, etc? I believe the output needed on a USB is 5 volt so suspect there may be something available, but I have not ran across a proven solution. I heard a rumor that a 12 volt car USB charger will work on a 6 volt bike but I am hesitant to try it on a $1000 phone or $500 GPS
    Jason Zerbini
    #21594
    Could you hook up the charger and measure the voltage coming out before connecting your phone.
      I get the question . . .I also just keep smiling to myself that we've gotten to the point where guys on 6v systems are worried about phone charging and having a GPS.
      To the answer, almost any 12v charger will work fine but will put out very little amperage.
      You can't get around Volts times Watts = Amps
      In this case, rather than a 3amp charge coming out; you'd get around 1.25-1.5a at 5v.
      That's gonna be fine for small devices or if your phone is mostly off, but if you have a current hungry device; you won't stay ahead of the battery.
      If you don't find what you like on AMCA . . . know that this is a common question across the old car world and there are multiple videos/articles from clubs on the topic.
      The most common solution - just wire in a regular USB port and live with the lower amperage output.
        Jason, I always assumed there's no way to charge a phone with a 6V system, so I'm interested to hear! On the other hand, we're all different and I usually remember to put my phone in "airplane mode" and that cuts way back on battery use, it lasts all day and my wife can still track me when it's in airplane mode.
          Alright I'll give it a try then. Thanks. Indeed we are a weird bunch to want high tech on a low tech bike. But hey... thats what happens when we ride them for more than a trip to the ice cream parlor. National Road runs are trending towards using "Ride GPS" or similar apps for route management which adds incentive to run an easy to read GPS unit. The other option is to not worry about it and follow the guy in front, but I learned that doesn't always end well! Or if I need to pull off for some reason even for 2 minutes the group keeps going and then I become leader not follower.
          Hi Harry - Agree my phone and even the Zumo X2 GPS will last throughout the day on a full charge. My problem is absentmindedness occasionally forgetting to get a full charge before heading out and by the time I pick up phone to leave and see its not charged, its too late. I'm more focused on the bikes prep. The screen readability on the X2 GPS going down the road in bright sun on an old vibrating bike is far superior to my phone so I want to start using that more. Getting spoiled on the ADV bike maybe.
          We had a Chapter run Sunday and I experiemented with a new Insta360 X5. Battery life on that camera is not all day so either a spare battery or charger would be needed depending on amount of filming.
          Jason Zerbini
          #21594
            I carry a portable power bank with me on trips, about the same size as my phone. Can charge my phone quickly or if needed charge my portable tire air pump. Maybe an option for now Jason.
            Bob Rice #6738
              i need something like this as well to operate the gps odometer/speedometer on my cannonball/cross country chase/trans am race bikes.
              currently i have been using a small 12v sealed battery in the toolbox with wiring up to the unit mounted on the bars.
                I dislike gps on a bike but if necessary I use ear buds with the screen turned off. It uses next to no battery.
                  I think a clever person could mount and wire one of those tiny lithium jump packs to run their devices all day. Make it a habit to recharge that when you check into your hotel room.
                  AMCA #41287
                  1971 Sprint SS350 project
                  1972 FX Boattail Night Train
                  1972 Sportster project
                  1973 HD Golf Cart project
                  1989 Springer Softail project
                  2020 Heritage Classic 114
                    Something like this
                      Originally posted by PanheadFred1 View Post
                      Something like this
                      Is that solar charged? Details, typically how long does it take to charge and/or can it charge while delivering a boost etc.? Thanks.
                      Bob Rice #6738
                        Yes, it's a solar charged battery pack. It charges in sunlight or with a USB cable . See 4 Patriots.com for details
                          I used a rechargeable GPS odo/speedometer on The Chase that was made for a bicycle, worked perfectly coast to coast. Yes I recharged it at night in the hotel but it never let me down during 8 hour riding days. Pretty sure I was charging it every other day. Amazon has lots of options for bicycles, no idea what brand I currently have for my bike.
