Which Battery?
  • Peter Cooke
    • Aug 2012
    • 570
    Which Battery?
    Hi folks,
    I'm almost finished my H-D 31V and need to get a battery. As I'm restoring it I've got one of those gutted resin copies of an original battery so am looking for something that'll fit inside which pretty much narrows the field to Lithium batteries. The one shown at the link below is what I'm considering and I can get from the local "motorcycle stuff" chain store which is a bonus. What I'm not sure about is the amp hour rating which seems quite low at 2.4 but may not be an issue given the gen is converted to 2 brush, with an electronic regulator, and the head & tail lights have been converted to LED.
    I noticed at the bottom of the page it says "replaces B38-6A" which I think is a commonly used 6v battery in old bikes so it may be ok.
    SSB LFP612L UltraLite Lithium Motorcycle Battery | Batteries Direct
    My other option is to use a sealed AGM as per below which at 20 amp hour seems more than up to the task. It won't fit in the resin case but it's height would make it suitable that I can use the resin lid with it so I'd still have the original looking terminals poking out of the battery box.
    Power-Sonic PS Series Battery PS 6 volt 20 ah PS6200
    Member 'PRG' (Peter from The Ozarks) gave this advice back in 2020 which suggests that a Lithium should work just fine assuming the 2.4 amp hour rate is enough.
    "Search 32E two brush conversion, V Tronic electronic regulator and Shorai lithium iron
    battery on this and Classic American Iron’s forum and you’ll likely find your answer. I
    discarded that mechanical cutout and lead acid battery 9 years ago and have had
    thousands of carefree miles in all conditions since, never on a charger. The latest
    insurance to load reduction has been converting this machine entirely to LED’s enabling
    running headlight and spots with impunity in low rpm stop and go riding".
    Peter mentions Shorai Lithium Iron. I did find one (LFX18A2-BS06) that'd fit and is 18 amp hour but can't get it here in Oz.
    I'm getting way out of my swim lane with the whole 'which battery' stuff so would appreciate any useful info anyone cares to share!
    Thanks folks.
    Peter
    Dear Peter, I've used a lot of B38-6A batteries, which fit the VL case nicely if left in their cardboard box, and add terminal cheaters if the bike is going in for AMCA judging. The VL is relatively unusual because so little of the battery is visible compared with Indians and Brit bikes. With what you have and LED lighting I'd use the small local battery in the repro case.
    • Tom Wilcock
      • Jan 2008
      • 333
      Because of lithium-ion batterys bad record of starting fires I stay away from them. I use sealed lead acid batteries.
      • Skirted
        • Sep 2012
        • 707
        Been using the Shorai BS06 for around 13 years in various 6 volt applications. Peter "PRG" was the one who recommended Shorai. Awesome battery but MUST make sure your electronic regulator doesn't exceed 7.2 volts. This is why they should never be used with a 3 brush generator. My personal experience has been they like a steady 7.1-7.2 volts charging rate. I never fuss putting a battery tender on any of them during winter season which can be as long as 5 months. Voltage stays stable and bikes fire right up in spring. My oldest BS06 lasted 11 years and was on a bike that saw a lot of use.
        Jason Zerbini
        #21594
        • joe fxs fxr
          • Dec 2020
          • 697
          My experience with a lithium battery has been with an AntiGravity in my chopper. It's an EVO motor and charging system, and that's the key. As Skirted says.high charging voltage will cook them, and cause fires. You DON"T NEED a tender with a lithium battery - just disconnect it during winter storage. In the spring, wake it up by turning on the headlight for 30 seconds three times. Then it's ready to fire up the bike. This spring will start the fourth season with that battery. Previous AGM batteries never lasted two whole seasons because the battery is in the oil tank.
          AMCA #41287
          1971 Sprint SS350 project
          1972 FX Boattail Night Train
          1972 Sportster project
          1973 HD Golf Cart project
          1989 Springer Softail project
          2020 Heritage Classic 114
          • otis71
            • Jul 2015
            • 597
            I use the sealed AGM batteries designed for alarms and emergency lights. Available in 12 and 6v. They last forever and seldomly need a charge. Two smaller ones wired in parallel generally gives more amperage and usually a better fit. Only downside is they give little notice when they go bad but if running two you always have a backup. Available everywhere and ridiculously cheap.
            • Peter Cooke
              • Aug 2012
              • 570
              Thanks for the feedback, folks. Seems almost like a 50/50split. What I have discovered today is that the local "motorcycle stuff" chain store doesn't stock the SSB 6v battery, so I'd need to order one anyway.
              Further investigation revealed that there is a Shorai stockist here in Oz and whilst they don't have LFX18A2-BS06 in stock they do have LFX18L2-BS06 which is the exact same battery but with the terminals reversed, which will suit better anyway. So, I'll be ordering that one.
              I also noticed that some sites list it as 6 Ah and some as 18 Ah PbEq. I found an interesting article that explains why. Extract below.
              "Several companies are now providing a Lead Acid Equivalent (Called Pbeq) rating for their lithium batteries. This rating is meant to allow easy comparison between lithium and lead acid batteries' capacity. The basis for this ‘PBeq’ rating lies with the discharge characteristics of lead acid batteries. As a general rule, a lead acid battery will supply about 30% of its actual Amp Hour capacity rating. As an example, a lead acid battery that is rated at nine (9) amp hour will supply roughly 30% of that capacity when you also keep voltage above 10v. Since lithium batteries are much better at maintaining voltage over the same discharge cycle, some lithium battery manufacturers are therefore tripling their actual capacity figures".
              Also, something I forgot to ask in my first post is regarding fuses. I'm considering putting one in between the battery positive and where it connects to the resin box positive terminal, inside the box. That way everything is protected before it splits off to the dash and the relay.
              Is 15amp about right or should it be higher or lower etc?
              Again, thanks for all the assistance.
              • dukekleman
                • Jul 2022
                • 595
                Peter,
                I use a 20 AMP fuse on the B+ (positive cable) of the battery.
                The required fuse can change based on variables of a particular motorcycle. The 20 AMP meets most needs so it is safe to recommend.
                You can perform an overall Amp test and see what your system requires exactly if necessary.
                I hope this helps,
                Duke Kleman
                • Peter Cooke
                  • Aug 2012
                  • 570
                  That does help thanks Duke. I'll start with 20 and see how we go.
                  • Lyle Manheimer
                    • Mar 2008
                    • 193
                    Peter, If you have no means of measuring current, ammeter, I would start with a 15 amp fuse. Start the bike turn, on all lights, step on thr rear brake, and blow the horn. If all is ok I would stick with 15. The horn being the biggest current draw.
                    • Peter Cooke
                      • Aug 2012
                      • 570
                      Thanks Lyle. Another good idea. And an easy one!
