741 Ignition Switch Repair
  • JTR249
    • Jul 2019
    • 768
    Anyone know a repair specialist for the 741 ignition switch? Mr. Whittington said he does not repair them.
    Here's the issue with the one I need repaired:
    “This is a rebuilt ignition switch for an Indian 741b. Should also fit WLA I rebuilt the switch for my bike using parts from two. I recently came across someone selling the rear contact plates new manufacture. I purchased one for myself and I installed the other into this switch making it functional again. Everything was cleaned before assembly and Lubriplate was applied to the contacts. I had painted it at some point but some has scratched off. This includes a new key but not the terminal screws. The barbell contact has wear but has been rotated to a fresh portion of the contacts. Because of its age I must sell it as is.”
    Seller John Huber's description.
    -JR
  • PaulCDF
    • Aug 2019
    • 1422
    JR
    On fb there is a Mr. Mike Lopiccolo in California who I believe works on Indian ignition switches. If you want I can message him to get his contact info for you.
    • JTR249
      • Jul 2019
      • 768
      Sure, Paul. Sounds good.
      Thanks.
      -JR
