what is this?
  • 68bagger
    member
    • Mar 2010
    • 23
    what is this?
    I bought a 46 FL.It is together but none of the wiring is connected. The pictures show the generator and voltage regulator. The wires from the regulator are black. No ID as to where they connect. Is this a generator or alternator? There are no markings on it. The previous owner told me the bike had been converted to 12 volts. It does have a 12 volt battery. Any help with wiring would be appreciated. Thanks Scott
  • joe fxs fxr
    • Dec 2020
    • 697
    I can't help you but post a picture of the regulator plug. That is how they get identified.
    AMCA #41287
    1971 Sprint SS350 project
    1972 FX Boattail Night Train
    1972 Sportster project
    1973 HD Golf Cart project
    1989 Springer Softail project
    2020 Heritage Classic 114
    • 68bagger
      member
      • Mar 2010
      • 23
      regulator 3.JPGThere is no plug, only about eight inches of wire. All three wires are black, no labels.
        • 4785
        Mini-alternator set up to resemble a three brush generator, and a solid state regulator to go with it. Don't know who made it.
        • 68bagger
          member
          • Mar 2010
          • 23
          Thanks for the replies. I would like to use it if I can find out how to wire it.
          • joe fxs fxr
            • Dec 2020
            • 697
            On an alternator bike, two of the black wires go to the stator and one goes to the battery positive. I don't have my bike handy, but someone in the shovelhead section should be able to tell you what in order they come out of the regulator. It doesn't matter which way the stator wires are hooked up, it's AC at that point.
            AMCA #41287
            • 68bagger
              member
              • Mar 2010
              • 23
              Thanks, that helps.
              • dukekleman
                • Jul 2022
                • 595
                It's hard to say with the aftermarket manufacturers but...
                the Center black wire of the 3 would typically be your DC charge wire that connects to your B+ post at the battery.
                The other two wires would both be ACV wires for a full wave system.
                • 68bagger
                  member
                  • Mar 2010
                  • 23
                  Thanks. I think I understand now..
