magneto help
  • cscott
    • Oct 2002
    • 451
    magneto help
    restoring a 46 chief with an edison splitdorf mag bench tested worked great , after installation no spark? an ideas before i have to tear everything down to take it off. thanks chris
    • 1675
    ...when you look at it with the cap off, motor turning over, does the rotor spin?
    • gharper
      • Nov 2009
      • 528
      Plug this into the search box:
      looking for points for a 1947 Indian chief with a Edison Splitorf mag There was a recent discussion of the same issue.
      • cscott
        • Oct 2002
        • 451
        yes it does spin
          • 1675
          Gene's talking about this:
          Hello!I was hoping for a little help. I have been having a hard time starting my 47 with a Edison-Splitdorf Magneto. I think I figured out the problem. The rotor connection point seems to be burnt off. I ordered a new rotor and cap from enfield racing but I cant find points for a Edison-Splitdorf RM Magneto. Anyone know where
          • cscott
            • Oct 2002
            • 451
            thanks for the info
            • tomfiii
              • Jun 2007
              • 314
              Make sure lead from points to condenser isn't pinched to ground.
              • cscott
                • Oct 2002
                • 451
                checked lead to condenser no ground, but loose screw at junction block and turns out the threads in block are stripped, anyone think there's any of those around?
