Generator test bench wiring
  • LUVMYSHOVELS
    • Nov 2019
    • 25
    Does anybody have a basic wiring diagram for generator test bench. I have all the components, gauges, motor. I just need a simple diagram to complete. Thanks.
    • 8234
    I should never trust my memory, Luv,..
    But basically you ground the F, and momentarily connect the A through your ammeter.
    A horn button works well.
    Hope your motor is speed-controlled, and a big one!
    • LUVMYSHOVELS
      • Nov 2019
      • 25
      Thank You. The motor is big enough. Ijust need to run wires to gauges and go from there.
        • 8234
        Might you ever intend to test and set 3-brush generators, Luv?
        If so please refer to Palmer's for some tips, as he prescribes a two-horse with variable speeds.
