Early points part # question
  • BigLakeBob
    • 2767
    I was at a swap meet today and there were several unopened boxes (and you were not allowed to open to see) that were WW2 year orange and black HD boxes marked US Gov't surplus and said either points or breaker points, I can't remember, but the part # was HRD 1569-42. I called a friend and he said the # for early points, and I see now in my parts book, is 1569-30A or 30 depending on a set or just the points. I did not buy any and take the chance, so can anyone tell me what HRD 1569-42 part is. Thank you.
    Bob Rice #6738
    • 4785
    Most -42 part numbers are XA however XAs used standard -30A points, plus virtually all XA specific part numbers are 5 digit prefix. That number isn't in the XA catalog. And H-D doesn't normally use the prefix number on a different item so it likely is points for something, but not XA, WLA, UA, ELC, or any of the other normal timers.
      I believe they are the 1569-30A points but without the spring, which in wartime you were expected to re-use.
      • BigLakeBob
        • 2767
        Thanks Robbie and Steve, I should have bought a set to find out but didn't.
        Bob Rice #6738
        • Tom Baker
          • Feb 2011
          • 1
          The standard points set is the 1569-30A, the 1569-42 is a kit with the 1569-30A points set and the 1574-30 spring.
          WLA parts book.
          1569-30A Points set consists of 1569-30 plate, contact with point and 1573-30 lever, breaker.
          1569-42 Kit, circuit breaker point. consists of 1569-30A points set and 1574-30 Spring circuit breaker lever.
          so the 1569-30A is just the points and the 1569-42 is the points set with spring.
          • BigLakeBob
            • 2767
            Thanks Tom.
            Bob Rice #6738
