We’re talking1964 police spotlights here. I was told by a former police officer ,not from that time period. Police spot lights were flashing red on the curbside & steady clear on the street side. Red to notify the driver to pull over and clear to illuminate the street side for safety once stopped. I ask because I’m working on a police bike and now is a convenient time to wire the relay back into the headlight shroud clip. Of course wiring would run parallel with only the red lamp passing through the relay. Any input before I wire this in?
Police spotlights
Only that spotlight color, placement , and flashing pattern varied from state to state and in many cases city to city, etc. There wasn't a standard placement. Viewing of old photos will show you many variations including the Cycle Signal post mounted revolving light.Robbie Knight Amca #2736
Much appreciated. I’ll likely run the red lens with the flasher on the L/H lamp and simply control the illumination with its individual housing switch. I’m city driving for the most part so just running the R/H spot is more than I’ll ever need. Just wouldn’t want to make any enemies in the PD. Thanks again
If you don't want enemies in the PD, never turn that light on except at a show or the like, otherwise you are in violation of emergency vehicle laws.Originally posted by steuerm View PostMuch appreciated. I’ll likely run the red lens with the flasher on the L/H lamp and simply control the illumination with its individual housing switch. I’m city driving for the most part so just running the R/H spot is more than I’ll ever need. Just wouldn’t want to make any enemies in the PD. Thanks againRobbie Knight Amca #2736
That explains why I was told, Folks...Originally posted by Rubone View PostOnly that spotlight color, placement , and flashing pattern varied from state to state and in many cases city to city, etc. There wasn't a standard placement. Viewing of old photos will show you many variations including the Cycle Signal post mounted revolving light.
Final assembly of the nacelle (at least) was left to the dealer!
(That should blow Judge's minds.)
.....CottenLast edited by T. Cotten; 07-23-2022, 08:46 PM.AMCA #776
I have a set of blue spotlights & duoglide police type oil tank/battery tray available if anyone is interested.
