Hi Everyone: This mite be a toughie, however, I would like to see a wiring schematic for the fifties signal wiring color codes. My FL is a 1954. There likely was a bulletin on how the wiring was fed around (routed) as well as color codes on those FL's of the time. Especially routing to the rear fender signal bullet lites. Nothing in the old manuals on it in the wireing schematics as the signal feature would have been an accessory. Hoping someone has an instruction sheet to copy from the original signal lamp kit from the fifties...or possibly a "Shop Dope" sheet on it. Thank you in advance...
