I have double-wired my FX starting system somewhere and I can't find the error. When I hit the starter button, the starter turns and the solenoid engages the bendix drive and the motor turns. But I can't disengage it. I have to disconnect the battery ground cable.
I remember this as a somewhat common mistake and I used to shake my head when guys wired their bikes and brought them in with this problem. Now I'm one of them !!- and I don't remember what the fix was !! Very embarrasing. Luckily, nobody was there to witness it.
I think that most likely its the starter realy or a missing ground. But the relay is fairly new, as is the solenoid. Also, The starter button works properly and does not hang up. I must have done it when I took the motor out this spring.
I'm lnow its a common mistake and most guys will probably know the fix off the top of their head.
Please advise.... and don't tell anybody !!
