6 Volt Delco-Remy 16 Horn
  • John Guntner
    • Feb 2007
    • 190
    I'm confused. I believe part number 4829-31 Terminal Square Fiber goes on the outside of the horn. First goes 4729-31 then 4829-31 then the two nuts. My buddy thinks he go on the inside of the horn under the terminal screw heads. I've never seen horn with them still in tacked. Any veiws on this or answers as to how it goes? Thanks
    • 4778
    The square goes inside, the insulator with the lip outside to keep the screw centered in the hole. Both terminals are basically hot until the button is pushed and grounds one side, so both need to be insulated from the horn body.
    • RichO
      • Dec 2001
      • 903
      Robbie, If you put juice to one horn terminal and ground the other one ( Wire attached but not run to horn button for test of horn) and the wire sparks when touched to bare frame spot and the horn don't toot the horn is shorted out inside? But if both terminals are hot until one is grounded by horn button wouldn't it do the same thing? Spark where the horn button grounds out? Or as you say both are supposed to be hot and the horn's bad?
      DrSprocket
      • downunder vl
        • Oct 2009
        • 139
        Just working on a horn re-build at present. If any one had an exploded diagram of all the parts it would be of great assistance. I found this thread and an article from Perry Ruiter which are helpful. An exploded diagram would probably make it clear for all questions.
        Happy New Year.
        VL Phill
        • EricOlson
          • Jan 2011
          • 577
          I found this diagram in the "Harley-Davidson Panhead Service Manual 1948-1957 Rigid". Hopefully it helps.
          This gallery has 1 photos.
          Eric Olson
          Membership #18488
          • downunder vl
            • Oct 2009
            • 139
            Thanks Eric,
            I was looking for the wiring and insulators around the contact posts. This will go in my file, thanks.
