i have a 32e gen. and all the internals look great, but it is an oily greasy mess inside, does anyone know the proper way to degrease the windings?? thanks chris
32 e gen
32e gen
Hello Scott , I've always found the best way is to take apart (label or make note where the conections go) except the field windings and clean with carb cleaner , (an aerosol spray cleaner , you must be able to get it over there ??) clean all up with that and reassemble , the 32e's do get a bit oily in long service , best of luck , Ken
