Paul's 640 Bobber
  • Dave M.
    Paul's 640 Bobber
    Great pic Paul!
    I'm working on a Flathead Harley bobber with a similar look and have a question.....
    What did you do for a tail light? Is that an original era unit?
    There are plenty of 12 volt bobber lights available but I'm told will not accept a 6 volt bulb.
    Great look! Good luck with the firing issues.
    It's a glass IND tail lamp with a custom made bracket. I really wanted to keep the orig. fender tip and had to work around that. I'm looking for a used pillion 5 x 10". Fender has been drilled for it.
    12 or 6 doesn't matter. It's the style of socket. Which can be easily changed in most cases.
    Thanks---
