I was wondering if anyone had ever seen a homemade setup like this before? The symbol on the round item with the wire soldered in the middle indicates that it is a diode. There are different types of diodes but the symbol seems to indicate that this is a simple one-way current flowing diode. Yet, I could be wrong about it because while I know that diodes will only allow current to flow in one direction; I don't understand how this one could break the current flow when the battery is fully charged.
The gadget came off my 1948 Indian Chief that I purchased about 6 months ago. I rode the bike fairly regular until the generator stopped charging and battery died on a ride a couple of weeks ago. I pulled the cover off to check the cutout relay, and this contraption is what I found.
I am very familiar with the cutout relays used on Harley 32Es and John Deere Delco Remy generators but I have never seen one of these before. I found a broken wire in the generator and the fields look like they may need to be rewrapped. Just not sure what to do with this thing. Should I get a replacement cutout relay or should I try using this thing when I finish rebuilding my generator?
Thanks, Joe
Thanks, Joe
