What goes here?
  • Sport61
    • Mar 2016
    • 17
    What goes here?
    Does anyone know what bolts here?, 20160702_133943.jpgto The small bolt with the nut , Is it a wire ground ? Located behind the rear head where the frame backbone meets the seat post above coil and tank shift rod lever .1934 vld thank you. I know bad photo might need to be rotated right , new to this stuff.
  • vride5
    • Dec 2002
    • 93
    there is a plug sort of affair that goes there so you can take the rear fender off without cutting the wire
