32E Generator Field coil install
  • Jim
    • Sep 2001
    • 784
    I bought new field coils for my 32E generator. They seem too "fat or thick" and when I tighten the two screws through the housing to the shoe, they do NOT pull in far enough to allow me to slide the armature back in. I emailed Kurt at Flatlandmotorcycles and he told me that he has sold dozens a year and they never had any issues with them. He said they have to be made to fit... So, anyone know the secret to "Fitting" new coils?
    So, how do I flatten the coil down enough to allow me to slide the armature into the housing?
    "Know what I mean Vern"??
    OR should I just contact Rich Brown from CT?
    Thanks!
    Jim
    AMCA #6520
    • 6008
    I had the same problem. Gene Harper recommended using an exhaust pipe expander on the pole shoes. Worked like a charm.
    • Jim
      • Sep 2001
      • 784
      I suppose you mean to install the new fields and then insert the exhaust pipe expander INSIDE and then "expand" it? Hmmm... sounds like a good idea. But, Now I need to know where to borrow one locally.
      Thanks for the tip!!
      Jim
      AMCA #6520
      • larry
        • May 2009
        • 247
        Did you use an impact screwdriver?
        • Knotthed
          • Jul 2008
          • 195
          check this for tail pipe expander.
          http://www.harborfreight.com/automot...e/exhaust.html
          D.J. Knott
          AMCA #10930
          • Jim
            • Sep 2001
            • 784
            No, I used a Snap-On Screwdriver that has the "Wrench" fitting up near the handle. That way, you can really get a lot of torque with them...
            Originally posted by Knotthed View Post
            Thanks for that link! Although, tonight I am going to ask my neighbor... he is always buying obscure "tools". I will find one. (Free) ;^) I know a few guys that "may" have one now that I think of it...
            Seems kind of "funny" that these need to be "fitted". But, I suppose that the H-D ones are long gone (Unless the H-D fields had "fit" issues too?) and all we have are repops. I don't mind using reproduction stuff as long as it is decent. These are supposed to be made in the USA too.
            Jim
            AMCA #6520
            • KDR
              • Jul 2004
              • 99
              Jim,
              All field coils need/needed to be fitted no matter if OEM Harley or the reproductions. As I said, I sell a lot of these to generator builders and have never had any negative feedback about their install, quality or function.
              Kurt
              • gharper
                • Nov 2009
                • 527
                Jim,
                Don't try to pull them in just using the screws, you'll likely booger up the screws and not get them in tight anyway. Harbor freight has cheap pipe expanders, or get friendly with somebody at your local muffler shop. Have the pole shoes in place, with the fields and screws started. Once you get a good expander inside, just open it up tight and set the screws. It works very quickly. Be careful if you get one of the monkeys at Midas running a hydraulic expander, they could distort the case, just snug them up until the pole shoe is tight against the body.
                Gene
                • Jim
                  • Sep 2001
                  • 784
                  Originally posted by KDR View Post
                  Jim,
                  Kurt
                  Thanks Kurt, as you can see, I am taking your advice on how to fit them in. Seeing how this is my first attempt at repairing my generator, I have to learn some new tricks. I was just under the impression that they were a "bolt in" replacement. ;^) I didn't know that about the H-D ones either. Thanks for that info as well. I can relate these to a "rust repair" panel for a car in auto body work. When they are made, they need to be "fit" to the car. They always need to be "fit". To me, it is no big deal and I expect it when repairing with a rust panel, but to a backyard mechanic... it can be out of his experience range.
                  Originally posted by gharper View Post
                  Jim,
                  Gene
                  Thanks for the TIP! I never thought to use a hydraulic expander as I don't think it will take much to get the armature back in anyway. It looks like all it needs to fit is just a silly millimeter larger. Neighbor won't be home till the weekend. Looks like I will expand my search of "friends" for one, or just wait till Saturday.
                  Jim
                  AMCA #6520
                  • koanes
                    • Apr 2003
                    • 656
                    Your local auto electic shop will have a proper tool for the job. More of a precision tool than a pipe expander. Probably charge you just a few dollars.
                    Kyle Oanes AMCA # 3046
                    • Bro74
                      • Apr 2013
                      • 23
                      Who do we contact to get a set of these field coils?
                      RT
                      • Jim
                        • Sep 2001
                        • 784
                        RT
                        I bought my set from http://www.flatlandmotorcyclecompany.com/ and just to be clear... make sure you understand that new field coils will need to be fit to your housing. They are NOT a direct bolt in... and from what I understand, neither were original H-D coils. ;^)
                        Jim
                        AMCA #6520
                        • TimR
                          • Sep 2009
                          • 74
                          Jim,
                          When I replace field coils I use a magnetic compass and a battery to make sure the polarity is correct.
                          • Jim
                            • Sep 2001
                            • 784
                            Originally posted by TimR View Post
                            Jim,
                            Funny you should mention that! Another guy (RvP) had also told me to use a compass to see if the wires were put on backwards when I first started to diagnose my Generator problem. This originally started with this post: http://www.antiquemotorcycle.org/bbo...and-Headlights
                            You can see later in that post what I initially found out what my problem was!
                            Jim
                            AMCA #6520
                            • Jim
                              • Sep 2001
                              • 784
                              OK, I now have my coils installed using a tail pipe expansion tool. It wasn't too bad. I now have the ORANGE DOT coil installed as the regulating coil, and WHITE DOT coil as the Shunt coil. All the wires are white. Yes, I know that the Regulating Coil wires go to (+) brush and (3rd) brush and the Shunt coil wires go to (-) brush and the Switch.
                              Now... what is the easiest way to determine the wiring? just follow the 32E wire diagram? I have attached 2 pics of my gen. with wires labeled A, B , C and D. Hope that helps. Thanks for the help!
                              Jim
                              AMCA #6520
