anybody here know who rebuilds 1926 JD coils, I have heard that there might be someone out there?
JD coils
Rat (at Harbor Vintage) does them. You can do them yourself. Just get a six volt coil and insert in casing. Almost that easy. When I got my JD, the coil was completely wrong/gone. I ended up making even the 'bakelite' casing from paper layered with fiberglass resin over a mold. It's almost indistinguishable from an original and has a nice hot spark.
But if you want to have it done... give Dave "Rat" Scherk at Harbor Vintage a call.
Cheers,
Sirhr
I would appreciate if someone could share what aftermarket coil is used to replace the original. Thank you.Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
Steve, For a few guys in our Chapter who run an 12V alternator in the primary cover so the generator is gutted except for the gears to run the timer I've made a slightly larger cover that looks like the original coil cover and housed a regular m/c round 12V coil in it with the two plug wires coming out like the originals. You could still use the original 6V generator and timer with a 6V round M/C coil in it. These guys were Cannonballers and now others are trying it. Reliability is the issue not the originality. Not the answer you need but another way to skin the cat.DrSprocket
