26 jd plug in socket
  • 58pan
    • Apr 2011
    • 16
    friend wants to know where it should be located on the 1926 and how is it mounted and what it looks like that it mounts to any Idea???, It's # 8 on the diagram of the book he has but can't remember after 30 years of it sitting around.
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    On my '27, I think it's just above the battery box. Perhaps on the seat post? Hang on and I'll see if I can find a photo...
    Cheers,
    Sirhr
    • sirhrmechanic
      Vigilis
      • Dec 2010
      • 1147
      The plug on my '27 is hanging from the tab on the seat post in front of (and above) the battery box.
      Cheers, Sirhr
      • 58pan
        • Apr 2011
        • 16
        thanks for the pics I think he still has the bracket and switch he just wasn't sure about the location
        • 58pan
          • Apr 2011
          • 16
          this tab peewee thinks is made of bakelite cuzz he found an old frame that he bought that has the tab on it, is he right or is it metal?
          • sirhrmechanic
            Vigilis
            • Dec 2010
            • 1147
            The tab is metal. May be brazed to the frame. I can't recall a fastener.
            The plug itself (female socket) is bakelite.
            Cheers,
            Sirhr
            • DanM
              • May 2005
              • 465
              up thru 27 the bracket is basically a clamp around the frame, not unlike how a muffler hanger works. In the free end of the clamp is a brass fitting. The brass is isolated from the clamp by fiber washers. A hot wire attaches to the brass. The accesspory lamp must have had a "banana" plug that would go into the center of the brass fitting.
              Later years had a different kind of clamp that secured a fiber board which was the insulator for the hot connection. Maybe this is what 58pan has found.
              Dan Margolien
              Www.yankeechapter.org
              Pocketvalve@gmail.com
              • sirhrmechanic
                Vigilis
                • Dec 2010
                • 1147
                I won't disagree with DanM. I am going by memory here. I can go out on the weekend and photograph the arrangement closely... but could easily be fiber washers. It's set up for a banana type plug for sure.
                Was this for an accessory lamp? Or for a trouble lamp of some kind? I figured the accessory would be hard-wired in. My '27 has an original type spotlight, but I wired it into the switch box.
                Thanks Dan.
                Cheers, Sirhr
