HD Special thread pitches
  • slamiste
    • Mar 2010
    • 260
    I'm planning on ordering taps and dies for the "special" thread pitches used on early Harleys. I primarily work on Big Twins from the 30's to the 60's but I'm also working on a 1924 J model. I'm aware of the 7/16 x 16 size used on some head bolts and the 1/4 x 24 size used on oil pumps and other parts. What other "special" sizes should I order?
    Steve Slaminko
    • 8230
    What carb is on the J, Steve?
    Even Linkerts need at least #12-24, 1/4"-32, 1/4"-40, 5/16"-32, 3/4"-20... etc., etc.
    HXs are far worse.
      • 4777
      Here are a few of the sizes used on H-Ds.
      https://www.hydra-glide.net/joomla/i...1184-tap-chart
      • kitabel
        • Sep 2018
        • 471
        K, KH head bolts 7/16-14
        The Linkert Book
        • slamiste
          • Mar 2010
          • 260
          Thanks everyone,
          The information supplied will allow me to pick which ones to buy.
          Cotton - The JD carb is stamped HX154.
          Steve Slaminko
            • 8230
            Originally posted by slamiste View Post
            Thanks everyone,
            Steve Slaminko
            Expect about another half-dozen weird threads for HXs at least, Steve!
            That is if you jump off the cliff, and try to do them right.
            Schebler even made HXs with a metric 14mm bore, so you will always need just one more tool.
