cylinder hones
    • 965
    cylinder hones
    I need to hone some cylinders to fit next oversize,std to .005.
    I usually send out cylinder and valve work but I am thinking of buying a Lisle 1500 ,or something similar such as some Mac,Amcos I have seen on ebay.
    Any feedback on ridged hones,especially the Lisle would be appreciated.
  • larry
    • May 2009
    • 247
    I use a Sunnen. Very similar to the Lisle. Works great.
      • 6017
      Are you talking about the hones you drive with a drill motor? If so, what kind of lubricant do you use, and is there anything special you need to be aware of?
        • 8234
        Not familiar with the Lisle,..
        But the AN Series Sunnen is the "cadillac" honing head, and I have used it with a drill as well.
        I believe "Delapena" is a similar design, and Goodson carries generic stones.
        I use the Sunnen lube.
        .....Cotten
        • larry
          • May 2009
          • 247
          Coarse stones are used dry, fine can be used dry or with lube. Follow the instructions that come with the tool. The system is fairly idiot proof.
            • 965
            Thanks for all the replies.
            I am familiar with Sunnen products but never see anything in the price range I am looking for and cant justify the usual premium price for my limited use.
            Any opinions on the lisle medim grit280 as a finish stone or would the fine stones 500 be better for finishing for cast iron rings?
              • 8234
              Tom!
              Did you price the Delapena alternatives of similar design: http://delapenausa.com/honing/vertical-tooling-2/
              Please remember you only need the stone holder head itself, and the rest you can fudge.
              I got my Sunnen at a local auction; Sadly, there aren't that many auto machine shops left to go out of business.
                • 965
                Tom!
                Thanks Tom.I looked at the link and didn't see anything that looked like it would be in my price range.
                Unless something pops up on ebay I will most likely get the Lisle.
                Some interesting info on Hasting site for cylinder finishing.
                Thanks again
