Chief rear shock tool
  • 48indy
    • Feb 2010
    • 5
    I have to remove the rear shocks on my 48 chief. Someone told me that it's pretty simple to make the tool you need to take them off. I'm pretty handy and l would like to make it if someone could discribe to me the tool measurements and thread. It looks pretty simple in a picture I came across , but still can't tell by a picture .
    • Aug 2001
    • 1343
    Picture from internet.....
    Louie
    YouTube >>> LouieMCman
    • 48indy
      • Feb 2010
      • 5
      Thanks, now I have a much better idea.
      • phillie
        Young Blood I think..haha
        • Jun 2011
        • 97
        I need to pull mine off too. Does anyone know the thread size? Also the length of the slug on there? Thanks
          • 963
          I made mine by welding an old top bolt,that has the grease fitting, to the threaded rod,and grinding off the nut flats.Crude but simple.
          • jim d
            • Sep 2010
            • 280
            The spacer is 1 and 1-8 o d. by 3 and 3-4 long, I think mine is a piece of electrical conduit. The inside is a piece of 3-4 threaded rod with a standard nut welded to the end. The rod is 6and 3-4 long including the nut welded to the end. The other end was cut down to 5-8 dia. and3-4 long, this was then threaded to 5-8 by 24 threads. All of this was done on a lathe because the threads are not standard. You can do as Tom and just weld a old top bolt on the end of the rod.
            Jim D
            Jim D
            • phillie
              • Jun 2011
              • 97
              thanks Jim!! my bro has a machine shop I will go see him!
