1928 JD Motor
  • MMasa
    • 1192
    MSkeene
    That one on eBay is a 1925-29 style. It is also damaged and overpriced.
    I'll take a look and see if I have a spare with gears etc.
    Are you looking for a cover and correct oil pump too? Be aware that there are at least 4 variants of the stamped steel gearcase cover that the oil pump mounts to.
    That I'm almost 100% sure I have extra cover and oil pump.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • MSkeene
      • Jun 2017
      • 17
      Mark, thank you for the feedback! I am looking for the cover and correct oil pump as well. Thank you for the help!
      • MSkeene
        • Jun 2017
        • 17
        Hi all, I have a quick update on my project. I had been talking to Mark Masa (MMasa) and he had an oil pump that would fit my motor and I was able purchased it from him, thank you Mark. I have attached some pictures of the pump. Also I had a few questions regarding some small cracks that my motor has in it. I need some advice on how to repair these cracks. They are mainly small hairline cracks and I would like to repair them all now so they do not turn into bigger problems later. I have attached some pictures of the cracks as well. Any advice would be appreciated, thank you!
        • Steve Swan
          Possessed by Motorcycles
          • Aug 2013
          • 1589
          Mitchell, glad to see your posts and experience thus far !
          When you look at the inside of the cases, do you see any cracks coming through from where the cracks are on the outside ?
          As i understand it, the cracks around the rotary breather are not uncommon. Those with greater experience will know about the cracks around the pinion shaft area. The aluminum of the time these cases were cast from was of the highest quality possible, but not as impurity free as contemporary aluminum. Casting processes of 1928 compared to today also influence the ability of the casting to withstand factors exerted on the castings.
          My LH case had a pair of V cracks beginning from the inside and outside diameters of the rear mount holes, extending in to the belly of the case. I was able to find an excellent welder of aluminum in our area and a local machine shop to machine the repaired surfaces. My RH case had no cracks
          As to the location and nature of the cracks (appears 4 in total?) in your RH case, those with more experience can share their knowledge for the best approach for the best repair of your cases. And how to best ascertain what cracks may exist, not visible to the naked eye. Our group has some or know of very talented, highly skilled people that can fix almost anything that looks beyond repair.
          Know that anything 99 years old, restoring, repairing or fitting back together will much of the time be a one piece at at time process. In my case, these challenges were not to be discouraged by, but as an opportunity to learn. i will say at times i was dismayed by the next "surprise" i discovered or encountered, but each issues resolved was one step in the progress toward firing an engine that would move the project down the road.
          Builds such as yours are always a great learning process of all of us, so i will be following your thread with anticipation. You are off to a great start !
          Steve Swan
          27JD 11090 Restored
          27JD 13514 aka "Frank"
          • MSkeene
            • Jun 2017
            • 17
            Steve, I don't believe that the cracks go all the way through. I think my next step is to take the cases apart and see if the cracks go all the way through. I also need to get, or make, a tool that can take the engine case nuts off. What type of tool did you use for this? Also how do I take off the one gear that I have in the bottom end of the motor? Does it unscrew or do I need to pull it off? I need to take that off to split the case I believe. Thanks again Steve for all of your help and suggestions, I appreciate it!
            • MMasa
              • 1192
              Colony Machine www.colonymachine.com makes a tool for the slotted nuts. Their part number 2594-1 on page 40 of their current online catalog.
              The pinion gear is just a light press onto the pinion shaft but the large headed screw needs to be removed first. This is a LEFT HAND THREAD screw and is usually somewhat tight.
              The cracks around the pinion shaft and breather gear will need to be welded and machined.
              There's a good guy here in Ohio for this if you can't find someone local.
              You're in California, right?
              Cracks around the breather are common. Around the pinion, not so much.
              Mark
              Mark Masa
              www.linkcycles.com
              • MSkeene
                • Jun 2017
                • 17
                Mark
                Mark, thank you I will order that tool from Colony Machine. I am in California, I do know some welders. Do you think I need to take it to a welder that usually repairs engines? Or will a good aluminum welder be able to get the job done? Thanks again for your help!
                • MMasa
                  • 1192
                  You should use someone who repairs early engine cases. They will also need some machine work done afterward.
                  Are u in northern or Southern California?
                  Mark Masa
                  www.linkcycles.com
                  • MSkeene
                    • Jun 2017
                    • 17
                    Ok thats what I thought. I'm in Southern California.
                    • MMasa
                      • 1192
                      Do you know George Hood?
                      He's in SO-CAL and would probably know of a good local resource.
                      If not, email or PM me and I can get you his contact info.
                      Mark
                      Mark Masa
                      www.linkcycles.com
                      • Steve Swan
                        • Aug 2013
                        • 1589
                        not to hijack Mitch's thread, but what are the reasons for cracking around the rotary breather and the pinion shaft ?
                        although the cracking in the breather area is most often seen, the rotary breather it's self doesn't seem like there would be that much load to area.
                        is the casting design it's self contribute to cracking ? or is it also in part due to the cast aluminum of those times not being up to the task?
                        or is it debris in the oil causing undue loading of the shaft that stresses the casting or a tooth breaks off a gear and gets jammed in the other teeth of the gears........?
                        Steve Swan
                        27JD 11090 Restored
                        • whp
                          • Nov 2015
                          • 26
                          #27
                          I'm going through the process of repairing cracks right now. I'm stumped on how to remove all the oil from the casting as it is almost a sponge. Maybe vapor degreasing? I've had it in the oven a dozen times and the welds are turning out like chicken poo, also they spur more cracks during the welding (casting is hot). After a few rounds of welding and sanding its getting there. Most aluminum welders are used to fresh oil free castings so this old stuff throws them for a loop.
                          Steve, I've heard it's old piston rings that get chewed up and get sucked into the breather gear as the crank case pressure is expelled. The piece of ring gets stuck and BAM! Shes cracked.
                          Bummer about your pinion area being cracked...
                          • Steve Swan
                            • Aug 2013
                            • 1589
                            #28
                            Ouch ! I felt that BAM! part clean through my smart phone.....
                            Steve Swan
                            27JD 11090 Restored
                            • MSkeene
                              • Jun 2017
                              • 17
                              #29
                              WHP and Steve,
                              I am bummed about the cracks too. Once I split the cases I will have a better idea about how far the cracks actually go. Luckily most of the cracks appear to be very thin hairline cracks, which hopefully can be repaired. WHP, do you have any pictures of your motor and your welds? I ordered the tool for the engine case slotted nuts, once I get that I will have a better idea about the cracks. Thank you guys for your help and sharing your experiences
                              • Steve Swan
                                • Aug 2013
                                • 1589
                                #30
                                Mitchell, i'm really happy to see you keep coming back and having the enthusiasm.
                                yes. cracks. i know the feeling. Be ye not faint of heart. more than one of us started with a few damaged parts that began our conquest.
                                after i got my pieces home in 2013, when i discovered the pair of V cracks that extended into the belly of my LH case, my heart sank into my shoes for a brief moment.
                                it's nothing that time, research, networking, persistence, perseverance and money can't fix. most rewarding will be everything you learn along the way, the great people you'll meet and when you complete the project, you'll know far more than you ever knew before you began. make the project as fun as you can !
                                the really great thing you have in your favor, you are 21 years young ! not many your age have the opportunity you have. you don't have to get the project done by next Thursday. just keep picking away at the pile, one part, one deliberate move at a time. each part you spend time repairing and fitting to another part is another triumph accomplished in the journey. another nice thing, you can make the bike what you want it to be and as time goes by, change it into something else. it can start out as an incomplete rider or a bobber, the first end result doesn't have to be a perfect restoration, but over time, if you wish, you can make it so.
                                i dreamt about having a JD for most of my life. the last 10 years, i KNEW i had to have one, i decided in my late 50's i wanted to have a JD to ride before i turned 66. i was 61 when i started my project. after i got my pieces, i kept the project on a constant move, juggling various aspects and finished when i am now 65....
                                imo, there's nothing more gorgeous than a restored IoE JD engine......
                                Steve Swan
                                27JD 11090 Restored
