How to navigate to the AMCA Vintage Motorcycle Library
This is a sticky topic.
  • ihrescue
    Super Moderator
    • Jun 2015
    • 1145
    This is a procedure for navigating to the AMCA Vintage Motorcycle Library
    For computers and tablets/iPads use this procedure; for smart phone access scroll down for that procedure.
    1) Use this link https://www.antiquemotorcycle.org to the home page of the AMCA Website.
    2) Go to the upper right of the screen and click login.
    3) Once logged in successfully you should see your username in the upper right corner of the screen.
    4) Just below your username is a tab named “FEATURES” this is where you’ll find a link to the AMCA Vintage Motorcycle Library
    5) Click on FEATURES and you will get a drop down menu - click on “Vintage M/C Library.”
    6) In a new screen toward the left and about halfway down you will need to click on a text link that says "Vintage Motorcycle Library AMCA Member Access Link”
    7) This would bring you to a page that is set up so you can do searches. For example today I found that there is a 1928 Indian Scout 101 parts manual.
    This image shows the search page and options available
    For access to the AMCA Vintage Motorcycle Library smart phones like iPhones, Android, Galaxy, etc use this procedure.
    2) Find the login link identified with a skeleton key - click to login, enter AMCA Member Website username and password and click GO on your screen keyboard.
    3) Once logged in successfully you should be able to access the sections of the website.
    4) At the bottom of your screen find the website menu of sections shown as 3 horizontal lines with the word Menu beneath it. Click and find the section “FEATURES” this is where you’ll find a link to the AMCA Vintage Motorcycle Library.
    6) A new new screen will come up and you should click on a text link that says "Vintage Motorcycle Library AMCA Member Access Link”
    7) This will take you to the AMCA Vintage Motorcycle Library to the page that is set up so you can do searches. There is a search window that allows you to enter a key words to search for in the library. You can also click on a link to browse all existing library files.
    Mike Love
    AMCA Forum Moderator
