greetings, looking for HD cyl numbers info
  • gww
    • Dec 2011
    • 143
    howdo, is there a place on here that would have data/info for identifying 50s,60s,70s HD cyls. if you could point it out to me i appreciate it. i have a old rat hole of cyls. id like to id to sell. thanks. gary
    gww57.com
    They are all date coded on the base flange. Usually with a letter, number, number. Like C 14 53 which would be March 14th 1953. The letter i was not used.
      • 4791
      Short answer is no. Longer version is that there are physical differences besides casting and date codes along with the fact date codes in some models repeat, so pictures are needed to identify them. And that isn't in a book somewhere or a simple chart.
      • gww
        • Dec 2011
        • 143
        much thanks.. would i bore the blazzes out of folks if i shared photos and info? and where would i do so? not sure there's any call for them anyway. thanks gary
        gww57.com
          • 6041
          Gary, the 'Harley-Davidson' for sale thread would be the best place. H-D cylinders do have unique characteristics and the people looking for the exact 'right' year are going to be very picky. I also happen to be looking for early Panhead cylinders but my requirement is that they be usable and I'm not that concerned about year codes, etc. If you have a pair of early cylinders that are still under the bore limit, I'd be very interested. Send me a P.M. if you do. Thanks, Eric
          • gww
            • Dec 2011
            • 143
            thank you. going to stick a list of the ones i,ve wrote down so far. see if there's anything there that would help ya before i start listing. thanks gary
            gww57.com
            • gww
              • Dec 2011
              • 143
              Harley Cyls
              cast# other#s bore cond.
              16568-66 138-70 3.466 clean
              16568-66 341-70 3.475 clean
              16568-66 n/a 3.478 clean (one broken fin)
              16568-66 n/a 3.466 clean
              16568-7 BF 3.452 clean
              16587-66 1229 214-71 3.470 clean
              16568-66 BF 3.447 clean
              16568-66 n/a 3.467 clean
              16568-66 BF 3.489 clean
              1656///// BF 3.459 will clean w/hone
              16568-78 0188 3.530 clean
              16568-78 020879 3.421 clean
              16568-78 BF 0179 3.535 will clean w/hone (one broken fin)
              16587-78 BF 0670 3.505 will clean w/hone
              16568-78 BF 6930 3.501 clean
              16568-66 BF 3.457 clean
              16587-78 3.531 needs bore
              S&S 80R 1175BF 3.494 clean
              S SF ? 3.518 clean
              16568-66 3.437 will clean w/hone
              sporty
              16581-57 J 4-0 3.016 will clean w/hone
              16581-57 L 13-0 3.017 will clean w/hone
              16561-57 K 14-0 3.028 will clean w/hone
              16561-57 K 29-0 3.016 will clean w/hone
              sporty heads 900
              6682-71 BC clean
              6684-71 BC 3 broken fins
              gww57.com
