1048 Indian Chief pattern
  • Joseph Mangelos
    • Oct 2019
    • 47
    I would like to change my Chief to a different shift pattern, I would like 1st back and 2nd and 3rd forward. It looks like I need to flip the transmission bell crank over and was wondering who do you recommend I buy it from?
    Thank you
    Joe
    • 1676
    Trying to wrap my head around this....what happens if you just reverse the bell crank lever on top of the shift tower so that it’s pointing up?
    Wait...I see Greer’s sells a bell crank specifically for this purpose! And couldn’t one simply machine in a second key slot into the existing bell crank so that you can reverse it?
      • 970
      Look at the tank shifter end .I think you can reverse the pattern there.
        • 1676
        Tom, if it’s RH shift I don’t see that happening...but like I said I’m trying to wrap my head around this!
        How about going to a Jockey style shifter, that may do it!
          • 970
          Forgot its rt hand shift with no option.
          Yes the jockey would give the desired pattern.
          You cant flip the trans lever because the exhaust port fins bulge out and would hit the rod.
          • hairynob24
            • Feb 2011
            • 348
            Joe I have done this recently and yes you need to flip the arm around , Tom is right too I needed to trim the fins down to clear for movement but I really like the set up . You cannt pick where I have trimmed the barrel . I got the gear level from a swap its a home made job rough but works get , plus I still use R/H throttle , Rob
