Vtwin risers
  • lrcormier
    • Aug 2010
    • 142
    Vtwin risers
    Recently purchased and returned riser kit 25-2175 (see attached), with this kit the hex bolt actually secures the entire riser to the tree effectively creating a solid riser like configuration. Did some more digging and found another vtwin kit 25-0021 which comes with oem looking type screws and lock nuts and with this kit the screws actually secure the inner rubber bushing allowing some movement of the riser, works like it should. The one slight thing wrong is that they did not install the cupped washers on the top of the bushing so I will likely find a washer that will fit. Otherwise this kit is a very nice item that could be used on a restoration. I also included a photo.
