Any feedback on these two dealers for Linkert carburetors: Into The Wilderness or abcgang, both on Ebay? Any other source who would be a good choice?
Recommendations for Linkert Carburetors
Leomags!
You are quite fortunate to find one, as they are relatively rare!
Were you lucky enough to get one with surviving nickel upon the body, and bronze bowl?
....CottenAMCA #776
Leomags!
If the body and bowl are both bare bronze, it means they have been molested of their original finish, probably by aggressive blasting, but not re-finished.
In AMCA terms, it is not "restored".
Ideally, the finish would have been patinated "dull" nickel, such as the bowl in my attachment.
If a 'restored' finish is desired, a brighter fuel-proof dressing can be used over the original nickel, preserving it for posterity.
PS: Note bright nickel pivot screw, valve, and bowl cap as well.Attached FilesLast edited by T. Cotten; 06-15-2012, 09:12 AM.AMCA #776
Leomags!
If you choose to re-finish by plating,
Please be aware that the manifold flange, aircleaner flange, and occasionally the lowspeed spring collar's seat,.. as well as the three bowl decks, should be re-cut or ground prior to plating, if they have not already.
Note also that traditional electroplating will deposit more heavily upon sharp edges than the rest.
Electroless nickel produces a far more consistant, and less destructive layer, although it will still be far more gaudy than the original, even when it was new.
Hammermarks and blemishes will be amplified by either process, unless dressed and re-textured.
Good luck!
....CottenAMCA #776
Would you think a a DLX-38 would have been nickled? I have this on my 26 JD and believe it was optional to the HX. I could not get the beautiful HX181 to run well and swaped this on till I have time to go through it again.Dan Margolien
Www.yankeechapter.org
Pocketvalve@gmail.com
Thanks!!!!!!!!!!!! Nice picture, too.Dan Margolien
Anyone else having problems with Into the Wilderness ? On june 7th I ordered $80.00 of small parts from his website and have not recieved the parts. Emails and phone calls have not been returned. I even called his cell phone no. listed and left a message and got no response. I emailed through ebay and did get a response asking when I purchased the parts. I emailed back a copy of all of the Paypal transaction details but got no response. I emailed again stating that I need to hear from him but again got no response. I have bought a few parts from him before and have not had any problems but this is unacceptable.Originally posted by leomags View PostAny feedback on these two dealers for Linkert carburetors: Into The Wilderness or abcgang, both on Ebay? Any other source who would be a good choice?
Bob Patza
AMCA no. 13275
Bob!
Microbusinesses are often subject to uncontrollable circumstances.
One health issue can bring things to a halt for weeks.
The entire vintage motorcycle industry requires interminable patience.
And then some.
....CottenAMCA #776
