Parts- can't identify
  • kg993
    • 263
    I have some lots of nos H D parts that are numbered but I haven't found the numbers in any of my parts books. Don't know what they are, guessing they may be for a Hummer, any help will be appreciated.
    43733-47 round felt gaskets 1 1/2"x5/8"x app.1/8" thick
    36467-61 square felt strips 3/16" x 3/16" x 4 1/2" long with ends cut @ 45 degrees
    34891-52 3/8-16 x 2 5/8 overall bolts for counter sunk hole has 5/16-24 threaded hole in head
    31430-68 5/16" x 2 9/16" shoulder bolts with 9/16" head
    43097-61P spoke nipples, only have 3.
    Kerry
    Kerry AMCA # 15911
  • vph-d
    • 1088
    The 61P part is for a Sprint. I'm thinking the -47 & -61 parts are also for lightweights. The -52 part is a sprocket cover bolt for KR, XLR, & XL models using straight pipes. The threaded hole mounts an exhaust clamp.
    VPH-D
    • kg993
      • 263
      I had a friend make a copy of Aermacchi pts. and manuels. The only thing I could find were the spoke nipples -61P are SX 175/250.
      I figured the -52 bolts were XL but had no proof for what model.
      I'm in pretty good with the parts guy at our local H.D. I may call and see if they come up on his screen.
      Thanks, Kerry
      Kerry AMCA # 15911
      • diesel55
        • Jul 2011
        • 262
        hello 43733-47 bearing felt seal left rear 1947 125 hd 36467-61 felt seal 1961 hd topper
