1946 Chief battery cable routing
  • rlassiter
    • Feb 2024
    • 25
    I’m trying to find the correct routing for the battery ground cable on a 1946 Chief.
    Any help would be appreciated. Thanks Roger Lassiter
    • 970
    If you have the overhaul manual you can see the wire on the rt.side engine pic,and there is a description in the eletcrical section.
    The wire goes around the back of the seat plunger frame tube and connects to the rear left tans top,not tower,1/4 20 bolt.
    • rlassiter
      • Feb 2024
      • 25
      Thank you for the info and help. I have a really old manual that is kinda hard to see, but I will look closer. I’m not sure about getting pics right now, I’m a first timer with the forum and trying to learn. Thanks again, Roger Lassiter
