1929 jd transmission
  • dakotadave
    • Jan 2016
    • 4
    I'm restoring a 1929jd
    Is 1925 transmission the same as 1929? Can you use a 1925 mated to a 1929jd engine?
    • 2025
    It is possible but not very easy. 1925 is a one year only transmission. It is the last year of the ramp style clutch throwout and the first year of the wider stance chassis. I would not recommend it. It is hard enough finding 25 parts much less adapting it to a 1929. I could look, I might have enough to built a 1929 transmission.
    Jerry
    • dakotadave
      • Jan 2016
      • 4
      Hi Jerry, thanks for the note. Would you look and see what you have for a 1929 jd transmission ? And get back to me. Thanks dave
      • dakotadave
        • Jan 2016
        • 4
        Hi Jerry, any luck on parts to build a1929jd transmission? Txt me Dave 701-793-7175
