I'm getting ready to put HS2 spots on my Panhead and not to sure of a few things. Where on the handle bar does the switch get mounted, and what clip do I use on the wires if any. Thanks
61 duo glide spot light switch
I believe it goes into a hole in the cowl, on the back side toward the rider. The wires run from the insulation board under the cowl beneath the headlight, and the power wires simply loop to the bottom of the spots. The spots are grounded through their mounting.
DanDan Margolien
Www.yankeechapter.org
Pocketvalve@gmail.com
