Cannonball firing order 1-3-4-2
  • 4thcoast
    • 31
    I thought I would provide a brief (if I can) explanation of the performance of the three four-cylinders that competed in the Cannonball Rally. I hope to explode a few myths about four cylinder engines and their ability to perform.
    Let me start by saying the stock connecting rods that teens-era four cylinders come with are completely inadequate for this type of endurance run at close to modern speeds. In preparation for building the two engines that I did that competed, I became obsessed with cycling oil through the rod journals to cool the journal itself and lubricate the cylinder walls. I designed and developed a connecting rod that would pressurize the rod journal and throw oil all over the side of the cylinder wall. I then used thin wall centrifugally spun cast rod bearings so that the heat from the rotating shaft could be dissipated to the bronze lining through the connecting rod.
    Of the three four cylinders on the run, one used these new rods and bearing inserts. It traveled 2,820 mechanically trouble free miles. Low and behold, the other two machines suffered - guess what? - catastrophic rod bearing failure. The 1915 Henderson failed within a day and a half, at which time the owner and I came to an agreement that he would purchase a set of the rods, bearings and pistons. Dimensions were taken, I phoned home to my shop, where the one guy in the country at that time who could have gotten it going, Mike Fockler, machinist extraordinaire and four cylinder convert, got the parts machined and sent to us in time to get the 15 Henderson back in the run. The motor was assembled by the owner and me at Foster Harley Davidson in Alabama and never suffered a lower end issue again.
    Chronic magneto failure plagued all of the four clyinders throughout the run. Around day 4, the Militaire's rod bearings 3 and 4 failed. We couldn't cycle enough oil through the stock design. The rod journals got so hot that the original soldered in rod dippers fell out and then starved the cylinder walls and overheated the engine. I was devastated about this. I had warned all four cylinder riders that if we had failure, it would be rod-related. My students at the University had worked so hard to build a bomb-proof bottom end and we had suffered the same fate as the 15 hen.
    Meanwhile, Westfall's Henderson, when not plagued with magneto issues, was marching across the country. As luck would have it, the 15 henderson that had blown up had two good pistons in it and the bore size and pin height was identical to that of the Militaire. That Militaire broke at the only spot in the country where I knew someone with the talent and willingness to help us put it back together - Russell Hughes, Master Pattern Maker and lover of four cylinders, 70 miles north of Hot Springs, Arkansas. We took two pistons from the 15 hen, fitted them to the Militaire bores, and headed for Russell's place. The Hughes family welcomed us with a traditional Arkansas catfish dinner, then Russell opened his shop and we worked into the night boring two new rod bearings, bushing the small end to accept a different sized wrist pin. I cannot thank Russell and his family enough for helping to get us going again. We assembled the motorcycle the next morning at Landers Harley Davidson in Hot Springs. Great people again who helped all the Cannonballers. We were able to coax another 1,400 miles out of the Militaire by picking our spots and avoiding prolonged hills (mountains). It was an incredible accomplishment for the owner of the Militaire for such an unproven design. My only wish for the Militaire was that we had had more time to test before the run. The Militaire is headed back to the University to undergo proper repairs and to give the owner and me a chance to test cam timing, carburation and cylinder flow.
    Westfall's Henderson was awesome. I never set the exhaust valves and I had to adjust the intake pockets 4 or 5 times. We broke one chain and burned through 4 magnetos. I have to thank Clyde Crouch who kept mailing us magnetos and having them show up, remarkably, when we needed them.
    There was a day when the 3 four cylinders, along with Slo Joe on his 14 Harley, finished in the first 4 spots. Total Nirvana moment for a four cylinder builder.
    With the exception of down times on the mag, we just witnessed a single speed Detroit Hen traverse the country. Great stuff. I hope this becomes an annual event. Folks on the Cannonball were extraordinary people. The willingness to help one another was my favorite part.
    I need to thank my students from the class of 2010, especially Matthew Wach, JaDon Spooner and Christopher Browning. We intend to start a new blog on the disassembly, measurement and inspection of the Cannonball engines of Westfall and the Militaire. Students will perform precision measurement and will provide a comparison of the wear patterns from the original set-up of the engines. If Cannonball is run again, I will be there. And it will be firing order 1-3-4-2.
  • Slojo
    Evil Twin Doctor
    • Oct 2007
    • 880
    Ghost Hunters
    While the Gray Ghost was a familiar front runner, the one exciting day the three Fours ran in unison behind the Ghost was a proud day for these absolutely fantastic machines and their riders. This particular day introduced the new term for the event "WOLF PACK". The Wolf Pack hunted the Ghost there after, what a great time we all had. Fortunately for the Ghost the Fours were unable to figure out how to capture a Ghost. It was all good and fun also.
    Joe
    • 4thcoast
      • 31
      Wolf Pack Rising
      Slojo,
      I built engines in my head all the way through the desert following you guys with the support truck. I see sodium filled exhaust valves, oil cannons taking aim at piston crowns. In between all that daydreaming my phone rang. A lot. There's a new wolf in the 1916-1929 pack and I might just have an ACE or two up my sleeve... Honestly Joe, it was great fun and that day that you, Jim and Frank ran the extra time, I felt you should have gotten that time back. (road washed out in New Mexico) Can't wait to do it again. have you heard any word about next year - I'm hooked.
      Mark
      • Buzz Kanter
        • Jan 2002
        • 539
        Mark, thanks for sharing all this. I am blown away watching you wrenching pretty much every night and always with a smile on your face.
        Buzz Kanter
        [American Iron Magazine Harley Magazine
        • Slojo
          Evil Twin Doctor
          • Oct 2007
          • 880
          Originally posted by 4thcoast View Post
          Slojo,
          Mark
          Mark the only word I have heard is unconfirmed so no scene in starting a roomer.
          Joe
          • Tom Lovejoy
            • Aug 2006
            • 951
            Right on 4thcoast, fascinating reading. Frank Westfall's Henderson sounded awesome as it went by, missed the Militaire but would of loved to hear it go by as well. Wolf Pack - right on!!
            • Greg H
              • Feb 2009
              • 143
              Thanks fo this follow up Mark ,look forward to the blog
              • 4thcoast
                • 31
                Tom,
                Thanks for posting the clip of Frank going by on the other thread. I had not seen that one. He was definitely the lead wolf in the pac. I think Buzz will agree seeing the people cheering you helps you cope with the heat, bike and fatigue.
                Mark
                • Buzz Kanter
                  • Jan 2002
                  • 539
                  Tom,
                  Mark
                  Cheering crowds does many things to a tired rider - almost all of them great!
                  Buzz Kanter
                    • 5954
                    I know guys with Model A Fords convert their babbitted rods and mains to inserted bearings. Perhaps you four cylinder owners should investigate doing this.
                    • schmittm
                      • Aug 2005
                      • 156
                      Aside from the connecting rod problems I found it interesting that one of the 4 cylinder entries did NOT have a front brake, an option that most of the other riders chose to add to their bikes before running them coast to coast. I had a conversation with him after dinner in Hot Springs and he had some questions about the route over Mount Magazine, I think I told him not to worry too much about it, Arkansas doesn't have real mountains, they are just Ozark foothills. I guess he made it down the backside of Magazine without incident (I hope).
                      Anyway, just wanted to pat all the prep and support guys, like Mark, on the back, their contribution to the event was as significant as the rider's efforts. Hope it happens again, I'll be there.
                      Mike
                      • Pete Gagan
                        • 233
                        I am currently working on a Pierce four. I've seen a few of these over the years, but they all seem to be in static collections. After seeing the performance of the 4's on the Cannonball, I've decided to make mine a dependable runner. Any Pierce experiences out there?
                        Pete Gagan
                        • Tom Lovejoy
                          • Aug 2006
                          • 951
                          Glad you liked it Mark, I have a Henderson - so your working's and finding's are of real interest to me. Way to go Pete, that would be quite the sight to see. Wish you the best with it, go Pierce !
                          • Greg H
                            • Feb 2009
                            • 143
                            Pete, have you seen the 1911 Pierce for sale @Yesterdays.nl
                            Perhaps those guys could hook you up with the restorer?
                            • Pete Gagan
                              • 233
                              Pierce
                              Contacting Yesterday's was an excellent idea, Greg. Their Pierce runs well, and is surprisingly fast according to Geert. He did say he had a friend whose Pierce exploded at speed, but he found and rebuilt another engine and takes it easier now.
                              My mods are dippers on the rods to pick up more oil, and I will finish the cylinders black rather than plated for better cooling- not maybe exactly correct, but more practical, and easily reversed.
                              Pete
