53 fle
  • Glenn
    Member to Remember
    • May 2007
    • 403
    53 fle
    can anyone tell me what an fle is
    thanks
    Moose
    aka Glenn
  • flat-happy
    • May 2009
    • 543
    it is a police motorcycle. sometimes they were sold to other govt agencies
    • Blupacer
      • Aug 2007
      • 88
      Hand shift with special carb and cams for city police work. Harley called them Traffic Combination Motors
      Steve
      Steve Cornish AMCA 6971
      TO MANY CLEVER PEOPLE NOT ENOUGH WISDOM
      • Barry Brown
        I had a 1955 fle ( E for police Escort) It had fantastic acceleration.
          FLE was a 74" engine with a carburetor and cam from a 61". The smaller carb provided more torque and acceleration on the bottom end but less speed on top end. They were made in both hand and foot shift models.
          • Slojo
            Evil Twin Doctor
            • Oct 2007
            • 880
            The carb is a M61 B. The FlE also came with adjustable trees.
            Joe
            • billpedalino
              • Mar 2005
              • 1096
              I Own a 1953 FLE, currently undergoing restoration. Most were sold to police agencies, but a few were also sold to the public as an answer to those who had a hard time giving up the 61" EL's. Yes, they did have the smaller carb and EL cam, although I'm probably going to use an M74B and FL cam, as it's not being judged. If I decide to have it judged, I'll mount the smaller Linkert M61. The smaller cam/carb combo certainy did give the motor more low speed power, but it topped off sooner than the FL's.
              Externally, the FLE is identical in appearance to the other big twins. I am not aware that the adjustable trees were available on all FLE's - My understanding is that they were part of the sidecar package only.
              Bill Pedalino
              Huntington, New York
              AMCA 6755
              • bmh
                • Feb 2007
                • 901
                Not sure but I think the gearing was different from an FL too. To my knowledge simply ordering an FLE didn't get you the adjustable front end, I doubt the factory gave you a free $7 option simply for checking a different box.
                Brian Howard AMCA#5866
                  • 4791
                  FLEs did not have adjustable trees, however an FS did. And I suppose an FS could be ordered in a Traffic Combination. I have a '54 FLE that will NOT be in Police trim. As Bill Pedalino stated anyone could order an FLE. Some were sold to funeral homes, some to commercial users who used them as courier bikes, etc. It was a state of tune, not an equipment package.
                  Robbie
                  • flat-happy
                    • May 2009
                    • 543
                    i have a MILK LICENSE plate that came off a 55FLE with a package truck on it for home milk delivery
                    • Glenn
                      Member to Remember
                      • May 2007
                      • 403
                      thanks for the replies this place is great and a wealth of knowledge
                      Moose
                      aka Glenn
                      • Slojo
                        Evil Twin Doctor
                        • Oct 2007
                        • 880
                        The adjustable trees statement I made was misunderstood. Some FLE pans did come with an adjustable tree for side car use. Low RPM tourque cam carb combination, an early taper-shaft compensating sprocket, and a grease hole in the center of the front bump of the diamond style primary cover (54 models). I own a 54 FLE since 1980, the previous owner supplied me with photos from the 50’S that clearly depicted the adjustable trees were on the bike back in the day. This bike runs excellent has the standard bore with about 25000 miles on it pulls from the bottom and keeps up with the standard FLH 74’S on the freeway without lagging behind. It still has the original 61” cam/carb combination and I see no reason in changing them. They also used valve lash caps.
                        1954 models came with both wishbone frames and straight leg frames. In 54 they had three types of D-rings on the pan covers. 1) Laminated steel as 49 thru 53 2) The rare six screw two fined cast aluminum D-ring 3) And the common single fin with six screw cast aluminum D-rings typically used in 55 also.
                        I am not sure of 53 but 54 had an identifying square boss cast located on the lower front Hydra Glide fork legs.
                        Joe
