What kind of garage heater are you using?
  • DanM
    • May 2005
    • 465
    I've put off installing a real heater for several years and now am ready. I'm considering the "Hot Dawg" blower type or the Radiant IR tube type. Propane fuel. Any thoughts/suggestions? THX
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
  • flat-happy
    • May 2009
    • 543
    well i'm in tennessee and i have a 3 ton a/c unit with a propane gas pack for heat with the flame outside so i can paint inside and the gas fumes don't bother either. when i lived in maine i had a wood stove like everyone else. i think if i move back i'll get a furnace that burns used motor oil and do oil changes on the side cheaper than anyone else to keep the supply up.
    • RSmith
      • Jul 2005
      • 214
      Mr. Heater
      Living in Michigan .... we KNOW the value of a
      heated garage from November - April!
      After trying Kerosun type kerosine and
      the torpedo jet engine shaped heaters that
      were loud and stunk, we saw the Mr. Heater
      radiant heater, at a Home Show.
      Our Mr. Heater Radiant heater was the BEST
      investment we have made for our garage,
      here in Michigan where it gets to -0 degrees,
      for long periods of time, in the winter.
      It comes with all the brackets and the
      thermostate does not require any
      electric hook-up.
      It heats our 2 1/2 car insulated/drywalled garage
      to 68 degrees, within 35 minutes, after sitting
      overnight at 40 degrees. Our natural gas bill
      increased $17 per month, in the winter, once
      it was installed.
      The radiant part is really nice when you are working
      on bike parts that are warm to the touch. It almost
      feels like the sun on you when you are working.
      It is QUIET and is safely installed 8 - 10 feet in the air,
      so low hanging vapors will not cause a tragedy.
      Below is the Mr. Heater website and some of the
      details from the Mr. Heater site. On their site are
      links to several on line National dealers,
      (Tractor Supply, etc), for easy purchase.
      Clicking on those links also gives the prices
      available.
      Mr. Heater Radiant Heater Facts -
      Easily Heats up to 500-600+ sq. ft. (2-1/2 car garage)
      No electricity required – heats during power outages
      Includes thermostat
      All necessary brackets and hardware included
      Available in propane or natural gas
      For Large Shops - 2 1/2+ Car Garages
      Utility buildings Loading docks
      Doorways/Ramps for snow prevention
      Storage sheds Patios
      Barns Outdoor smoking areas
      Roger Smith #1718
      AMCA Foundation Secretary
      • bmh
        • Feb 2007
        • 901
        1930's double burner heatrola with a fan and shroud on top (period modified ). In the dead of PA winter I can fire off both burners, put the fan on and go up to the house have breakfast and some coffee with the Mrs. (bout hour- hour and a half) and its warm enough to work, though everything you pick up off the floor is quite cool, by lunch I'm usually shutting one burner down or backing them both off to the minimum at the carb. Heats my shop which is the size of a two car garage real nice. Burns about a quart an hour with both burners on full, about a beer can full an hour with one burner on minimum.
        Brian Howard AMCA#5866
          • Sep 2004
          • 983
          When oil was hitting 3 dollars a gallon and climbing I took a lesson from going to Davenport for more than 25 years ( I visited a war buddy there before I even went to the club meet ) I switched home and garage to heat from corn !!! Its economical and enviro- friendly!!! Last winter I heated a 38x48 garage for less than 100 bucks and 70 inthere day and nite!!! And the best thing my money stayed here in the good old U.S.A. !!!
          • silentgreyfello
            • Nov 2006
            • 861
            The advantage to radiant heaters is that it is heating the objects, not the air, which is nice if working on iron. The open flame radiant heaters are not recommended where flammables (gasolene) is prevalent. I would recommend a radiant tube heater. Several suppliers out there, easy to install. I have installed several Hot Dawg heaters, as well as other unit heaters. Good for a garage, but they can be kind of noisy and move the air quite a bit. They are very simple to install as well.
              Heat? I need air conditioning.
              • aka HAWG
                • Jan 2007
                • 487
                and some kind of air purifier to clean the air as I hear from arnold, and that the rest of the country can help pay for
                aka HAWG
                1914 EXCELSIOR BELT DRIVE SINGLE
                1914 excelsior belt drive single carcuss
                1940 indian chief military
                1965 sportster xlch
                1969 sportster xlch bobber
                1971 bsa A65 chopper
                1969 harley ss350 sprint
                1960 harley topper
                1963 harley topper
                H model whizzer on cheiftain bicycle
                H model whizzer on schwinn bicycle
                1949 harley model 125 bobber project
                1959 harley model 165
                1960 harley super 10
                1974 indian 70cc dirt bike
                EXCELSIOR - ALWAYS MAKES GOOD
                • Kozy
                  • Feb 2004
                  • 129
                  Garage heat
                  Plenty of people are switching to higher efficentcy gas furnaces. Pick up one of their old units which are usually serviceable and sometimes can be had for the asking and hauling. The BTU rateing is usually high enough to heat up a two car garage in less than an hour.
                  • slarsonroy
                    • Dec 2008
                    • 106
                    I use an Electric furnace from a house that was torn down and I disconnected one of the 2 coil banks. I have a 2 car garage with 3 sides below grade that I heat with it only when Im working down there, otherwise it never gets below 40 degrees even in the dead of winter (Iowa). I bought it for $50 from the heating and cooling guy that installed my heating/cooling system when I built my new house. Ask around, I guess they tear a lot of good working units out when people upgrade to higher efficiency units.
                    Scott Larson
                    AMCA #13589
                    Omaha Chapter
                    1953 HD FLE
                    1971 HD FLH
                    1971 Triumph Bonneville 650
                    1973 Norton Commando 750
                    • rwm
                      • Dec 2006
                      • 1302
                      never use anything with flame you will lose and lose everything life ,your ride your house and your family so much **** burns parts cleaner wd40 paint thiner gas you name it a flash fire is bad news.
                      rob ronky #10507
                      www.diamondhorsevalley.com
                      • RSmith
                        • Jul 2005
                        • 214
                        UL Rated Heaters
                        "Mr. Heater" units were specifically designed for working garages like ours and they have sold tens of thousands of these units, since they began in 1986.
                        They have a 20+ year safety track record .... and the radiant garage heater we bought 5 years ago, from Tractor Supply, that mounts high on the garage sidewall .... has worked flawlessly .... even in the depth of Michigan winters ...
                        F.Y.I. - These UL Listed Mr. Heater garage heaters cost $250 brand new and take 2 hours to install.
                        http://cgi.ebay.com/Mr-Heater-25K-Na...d=p3286.c0.m14
                        • Rooster
                          • Mar 2009
                          • 543
                          Most all Fire Departments use the overhead mounted radiant tube heaters in their Engine bays during the Winter. As already stated, the radiant heat warms the machinery, and NOT the air.
                          I built a Fire Station once, and it had some tricky interface switchgear that would shut off the radiant heaters when the overhead garage doors opened!
                          Personally, when I build my new shop, it will have piping for circulating hot water in the concrete slab. My friend has this, and when you go to his shop, you want to take off your shoes and lay on the floor!
                          • RSmith
                            • Jul 2005
                            • 214
                            Helped?
                            Hope all this heater info helped ....
                            • KNUCK
                              • 828
                              I just moved to the hills below Yosemite Park and plan to install a Pellet Stove to take the chill off when needed.
