Restoring my 1968 Triumph Bonneville Any recommendations on rust remover / cleanerss. Do not have a sand blaster. Want to use something liquid. Dip in parts, nutes bolts etc has anyone used that prodcut advertised using a vegetable, beta vulgaris( isnt google a wonderful thing)?? Thanks
rust remover / part cleaner chemical
Rusteco
Jroberts -
Take a look at the Rusteco webpage
(address below).
They have been derusting the inside
of our tanks and other parts for years.
The product is non-toxic and can be
sent to you in pints or quarts.
They are also always happy to give
excellent advice over the phone.
For small parts, I purchased a rotary tumbler from Caswell.
Toss in a bunch of rusty small parts, add ceramic triangles, some water & dishwasher soap and presto - shiny parts!
jroberts,
When I restored my 51 Servi I used electrolysis to
de-rust many of the parts. Basically the part(s) are suspended
in a bath of water\washing soda between two metal bars and
then a battery-charger is attached, one pole to the part, and
one on the suspended bars. Will migrate all of the rust from
the part to the bars without damaging the part as does
sandblasting or chemical cleaners. You can find serveral articles
that explain the process in detail on the web (google).
For example I cleaned both back wheels this way and not only did
it remove the rust but the paint which had rust underneath. Be
ready to prime or coat the parts as once they come out of the
bath, they will start to rust again immediately.
Links for molasses rust removal (Beta vulgaris is the sugar beet!):
http://virtualindian.org/projrust.htm#molasses
Links for electroyltic rust removal:
I haven't the patience for either, when walnut hulls at 110psi will pick off rust without removing Parkerizing.
You're not to far from the Canton-Akron area. Try giving Lemans a call. You will find their phone number here....
http://www.lehmans.com/sdx/H21349.jsp If they do not have it, I bet they can link you to someone who does. They are located in the heart of Amish country. Paps
