Manifold test
  • hairynob24
    • Feb 2011
    • 348
    Manifold test
    G day, I have a question about manifold testing, senior moment, should the valves be in the closed or open position when doing a manifold test, ? Rob
    • 8246
    Just set your regulator to ~15 psi, Rob,
    Hook it up to your testplate, and it will rise and fall as you turn the motor through.
    When it is up to pressure, your valves are closed enough to bubble-test.
    If valves are excessively open, the air just escapes.
    • hairynob24
      • Feb 2011
      • 348
      Cotten appreciate your input just what I wanted to know cheers
        • 8246
        Even though its been nearly a quarter-century, Folks,
        This link still serves our hobby well:
        https://web.archive.org/web/20250615...hleaktest.html
        How ironic that modern brainiacs are 3D printing testplates with no bolt threads, or using Schrader valves that defeat the regulator..
        And selling them. Our hobby is doomed.
