Sealed 12V battery recommendations ?
  • eddiepanhead
    • Jan 2007
    • 171
    Would like to use a sealed 12v Battery in my kick start panhead. Any recommendations? Plan to use it with a solid state voltage regulator and a 65a generator.
    Thanks!
  • larry
    • May 2009
    • 247
    • joe fxs fxr
      • Dec 2020
      • 706
      Any of these will serve you well. I like Deka brand.
      AMCA #41287
      1971 Sprint SS350 project
      1972 FX Boattail Night Train
      1972 Sportster project
      1973 HD Golf Cart project
      1989 Springer Softail project
      2020 Heritage Classic 114
      • BigLakeBob
        • 2768
        I have the following set up in my '62 using a 65A and a solid state regulator converted into an original 6v regulator housing. I bought Tedd's 42-9987 box and lid. The box bracket where the battery sits had to be altered, as well as the lid to fit properly, but wasn't too hateful to do. You need to made wire connections from the battery to the cover. Overall worked out well, using this setup allows use of original lid, tie straps and battery posts are in the correct location. I bought a 12amp battery from Batteries Plus, not sure of the part #. 3 years now with no issues. You can also use a 6v hollowed out old battery but I believe only a 5amp battery will fit inside, there are also replica boxes made.
        Bob Rice #6738
        • eddiepanhead
          • Jan 2007
          • 171
          I have the same box that I've used in the past. Any chance you could see what p/n the battery is? Thanks
          • ChiefTwoKicks
            • Apr 2008
            • 282
            the part number is in the upper left corner of the battery... in the pic above. YUASA NP12-12 12V, 12.0Ah
            • BigLakeBob
              • 2768
              Don't have time to pull the cover right now, but looking over my receipts it looks like I used Batteries Plus # SLA12-9F2. 9amp battery that I stood on end.
              https://www.batteriesplus.com/productdetails/sla12=9f2
              Bob Rice #6738
                • 971
                I like the Dekas from York pa,America’s largest battery factory
                i ordered my las two 12v agm for chief and flht from Lowes online
                free shipping to local store and came with
                dste of manufacture two days previous
                HD oem are same factory and batteries ,off same production line but have hd logo
                web site lists dimensions
