How do I remove the clutch hub on a 1934 VL?
1934 Harley Davidson VL
Bottom photo is the correct tool, you can see how it works. Top photo is home made from junk, grind the bolt heads to fit the holes, use a socket between the plate & clutch shaft.
VL clutch puller.jpgRich Inmate #7084
