brass side valve type float bowl
  • ronniecox
    • Feb 2013
    • 27
    what does a solid brass float bowl fit
    • 8247
    There was at least four different bronze Schebler bowls, Ronnie!
    But if it is nearly identical to Linkert bowls, with 7-64 cast inside, it was for the M21:
    If there isn't 7-64 inside, then it is probably a Schebler DLX similar to the one on the bottom...
    All were nickel plated.
