sidecar wheel and spokes
  • Omarttentmaker
    • Dec 2009
    • 322
    Does anyone have any info on spoke sizes and installation procedures for a sidehack wheel on a 1919 H-D? How about a supplier? I looked on Buchanan's site and didn't see anything pertinent in regard to this. It would seem as though one could true the wheel after installing the spokes by just installing it on the straight axle on the hack. Any info appreciated
  • aumick10
    • Nov 2018
    • 467
    I sent my 29M hub to Buchanans, told them what size rim i wanted and they made the spokes to suit. Also supplied the rim
    • Omarttentmaker
      • Dec 2009
      • 322
      Actually, I was hoping to tackle it myself. I'll get in touch with them and see if they can recommend s spoke size and length. Thanks for the tip!
      • aumick10
        • Nov 2018
        • 467
        They sent the parts back to me and i assembled and trued it.
        • Omarttentmaker
          • Dec 2009
          • 322
          OK. I'll probably end up ding the same.
          • aumick10
            • Nov 2018
            • 467
            If they have the hub, you can be assured you have the correct spokes.
            • gharper
              • Nov 2009
              • 528
              You can do it al over the phone with them. Have the rim and hub in front of you and a way to measure spoke and nipple hole diameter, rim diameter (at the base of the rim, not the tire lip) width of the hub flanges and diameter of the hub flanges at the center of the holes. From there they can determine correct spoke length. You will need to decide if you want stainless steel, bare steel, straight or swedged spokes.
              • Ric Bolduc
                AMCA Member since 2000
                • Feb 2012
                • 109
                I can help you out if you still need it... You can PM me at ricbolduc@outlook.com
