Sidecar M/C info needed Duo-Glides
  • Magic
    I'm searching for a solution to a small but nerving problem with my Bicycle Kicker Pedal that hits the ground when I follow though with my kick. The M/C is a swingarm 58 H-D that tracks perfectly down the road and handles well! So that being said...I really wouldn't wanna change much. I have the correct original kicker arm on it and am slowly destroying an original Pedal as the 2 end pieces are being ground down. More so I don't want my trans cover bushing casting which last known was good to crack either! The Pedal does follow through and just scrapes the ground...Sooner or later it will stop once it grinds to it's limit! LOL I've thought of raising the rear shock tension although to no help. Is there any other Duo-Glide Side-car riders with helpfull info or like always am I the only one with this nerving little problem? LOL Thanks many,...Merlin in Pa. Ride them.
