wiring question
  • Omarttentmaker
    • Dec 2009
    • 322
    wiring question
    Looking at the pieces that make up the assembly for the fiber board that goes between the top and bottom trees on a glide. Why is there an insulated washer under the head of the screw? the board is already insulated, as it is made out of, I'd guess, phenolic. Anybody?
    • 8247
    I pulled one off the wall, Omar!
    And they look cad/rusty to me...
    PS: The phenolic is often called Micarta.
    • Omarttentmaker
      • Dec 2009
      • 322
      When I said "looking", I meant at the assembly drawing in the spare parts book. The part number is 71098-38, and it is described as a screw insulator. The dash number would indicate that it was used somewhere else on the bike earlier, but I kinda scanned through a few of the electrical sections and didn't see it repeated. The index only shows it appearing on page 170 of the spare parts book.
        • 4791
        The terminal board for the fork uses hex head bolts with nuts and washers. The picture I believe you are looking at is the hardware for the metal terminal box behind the coil.
        • Omarttentmaker
          • Dec 2009
          • 322
          You are correct, Robbie. My mistake!
