do you rotate your tires
  • do you rotate your tires
    i've got a 47 el with sidecar a few years ago i took the side car off i noticed that my front tire was kinda square it was a little tricky on turns without the car anyway now the tire wore to almost a point but there is alot of rubber on the tire, anyway now i need a rear tire i was wondering if i should rotate the tire put the new one in the front and the frt weird one on the rear maybe it'll square off again or should i just buy two new tires there arco 5.00x16 if i can still find them last ones i got at bills about 10years ago i see that firestone makes a tire with same thread patern any body try them
    pat
