old fender tips
  • old fender tips
    hi - were fender tips like these made to fit both harleys and indians? are these Indian parts or just aftermarket parts for any bike? i have seen these similar to the larger tip with the higher peak with no screw holes on the sides, instead having mounts on the back that you would have screwed into from under the fender. the big one is 7 3/4" tip to tip and the smaller one is 7 1/2". larger one marked 54 The Nation's Cycle Center, no markings on the smaller one. thanks for the info.
    Yes, aftermarket companies usually made tips for both H0-D and Indian with very different curves to fit the respective brands fenders. Also tips for British bikes and K models, so there are many configurations.
      thanks robbie
