Fantasy time.
If you could advise a modern motorcycle manufacturer as to what retro motorcycle you would like to see built with modern engineering practices to your own specs what would it be?
Here's mine:
An air/oil-cooled V-twin with counter-balancer and final shaft-drive.
It would FAITHFULLY follow the styling of the 1936 EL model Knucklehead.
It would weigh NO MORE than the 1936 Knucklehead.
It would displace no more than 1000cc.
It would have interchangable 4:00x18 wheels on it front and rear.
It would have a hinged rear fender and center-stand.
It would not have to have a spring fork (spring fork optional), but it would have to have a correctly executed EL front fender.
It would NOT have chopper dual mufflers but normal single type.
It would also have the old sprung seatpost as an option.
It would be available as an "RT" version with full frame-mounted fairing and hard-bags also with 1936-type styling.
Also a "bare" leather saddlebag version.
The engine would be stamped like the old bikes with the year and model and serial number.
It would have no more than 5 gears.
Chrome options would be limited.
Next?
Here's mine:
Next?
